NEED HELP LOCATING THE FLYWHEEL AND TIMING CONNECTOR
Old Mar 20, 2004 | 12:25 PM
southphillyman
Guest
Posts: n/a
Default NEED HELP LOCATING THE FLYWHEEL AND TIMING CONNECTOR
i have no idea where these two things are.
i put on a new distributor this morning and i need to check the timing. i got the cheltons book but it doesnt show visually where these parts are.
also is it safe to drive after changing the distributor housing and not adjusting timing? cause i just drove like 10 miles to school.......
the cheltons book says the connector is under the right front kick panel...in a 91 accord and is blue. i have no idea wtf a right kick panel is. and why do i have to find this anyway ,
i think the flywheel is what the timing belt runs on, but i didnt see any marks on there. somebody help me please, thanks
Old Mar 20, 2004 | 12:28 PM
fw190bvi's Avatar
Default Re: NEED HELP LOCATING THE FLYWHEEL AND TIMING CONNECTOR (southphillyman)
kick panel is under nearth the glove box right in front of the door hinges (towards the front of the car)......flywheel is part of ur tranny/drivetrain.......are u sure your not talking about the cam gear or crankshaft??????
Old Mar 20, 2004 | 01:06 PM
southphillyman
Guest
Posts: n/a
Default Re: NEED HELP LOCATING THE FLYWHEEL AND TIMING CONNECTOR (fw190bvi)
so the connector is under the passegner side , where their feet would be?
and the book said flywheel...i gotta look for marks on the flywheel and point the light gun at it. iono wtf this is about.
i called my mechanic and he trying scam me talking he gotta take the distributor off and all this ****
Old Mar 20, 2004 | 02:32 PM
cyberneo344ib's Avatar
it sounds like ur just trying to make sure its timed right. In the 91 you have only have it two ways, correct, or 180 degrees off. It is hard to see off of the fly wheel, so what I do is:
Take the plug wires off of the spark plugs.
Pull the number one spark plug.
Put your thumb covering the hole, but not into the engine.
Have someone turn the key to have the engine turn over once at a time, when the compression forces your thumb to come up, it is on the number one cylinder.
Now go to your distributor and turn it until it points the the number one terminal. Now put on the distributor and there you go.
Old Mar 20, 2004 | 08:07 PM
southphillyman
Guest
Posts: n/a
Default Re: NEED HELP LOCATING THE FLYWHEEL AND TIMING CONNECTOR (cyberneo344ib)
that sounds harder then the way the book says
prelude2.2vtec
Mar 3, 2009 04:31 AM
anomale
Nov 30, 2008 01:34 PM
deucedeuceEK
Jan 2, 2007 08:52 AM
92 in the works
Feb 23, 2004 07:30 AM
H23ludedude
Feb 20, 2003 05:23 AM
