OBD1 conversion components(OBD1 chipped P75 LS ECU, OBD1 converison harness)
Old Mar 20, 2004 | 12:10 PM
DA-MAX's Avatar
Default OBD1 conversion components(OBD1 chipped P75 LS ECU, OBD1 converison harness)
some of these components can be used for either an OBD0-OBD1 swap or an OBD2-OBD1 swap....
this is a p75 LS/RS/GS obd1 ECU...it can be used alone in OBD1 94+ Integras and is also perfect for OBD0 to OBD1 swaps(using the conv. harness) and also OBD2 to OBD1 swaps in Integras or any other car powered by a B18A/B. ECU is in perfect working order and was socketed by an experienced H-T member. the ECU will come with one 29C256 chip with the stock LS program on it. $105 shipped takes it!!
I also have an OBD0 to OBD 1 conversion harness as well...
this is a Boomslang OBD0-OBD1 converison harness...item is ready to install but was never used. comes with directions and ECU pinout. item sells for $150 new...get one that was never used for $105 shipped
(more info on Boomslang harnesses here http://www.boomslang.us )
both items can be had for $200 shipped if bought all together
stevil_knevil
Feb 10, 2009 01:39 PM
usdmDC4
Sep 8, 2007 09:18 AM
HybridKOOP
Jun 19, 2006 12:29 PM
brkdwn5
May 1, 2006 04:41 AM
