Breather on intake mani B18a
Old Mar 20, 2004 | 10:56 AM
OreoEF8's Avatar
Default Breather on intake mani B18a
Hey, you know the tube that comes up from that black square canister underneath the intake manifold to the right of the oil filter on a B18a. I broke the thing, and was wondering if i could run a straight tube from the canister to the intake mani. the problem is, the part that i broke is the "L" piece that mounts to the intake mani. it has a little spring and plunger deal,and i am wondering if i need that for it to breath correctly. Thanks to all that can help. EF squad
Old Mar 20, 2004 | 11:23 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: Breather on intake mani B18a (deliciousrex)
Thats the PCV valve.. and ide want to be using it since in most cases, honda doens't give you things you really don't need.
Old Mar 20, 2004 | 11:44 AM
manson's Avatar
Default Re: Breather on intake mani B18a (Built B16A)
replace the pcv
Old Mar 20, 2004 | 05:03 PM
Built B16A's Avatar
Default Re: Breather on intake mani B18a (mansonclubpuir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mansonclubpuir &raquo;</TD></TR><TR><TD CLASS="quote">replace the pcv</TD></TR></TABLE>
werd.. i think they're like 5-7 bucks at checkers..
Corey_sl
18
Apr 6, 2008 06:56 AM
91EF919
Oct 4, 2007 03:13 PM
rasta420
Acura TL, RL & ZDX
Sep 20, 2005 01:47 AM
trooper0641
May 2, 2004 01:27 PM
senpai
Jul 24, 2003 02:13 PM
