b20z pressure plate
Old Mar 20, 2004 | 09:28 AM
highcomp's Avatar
Default b20z pressure plate
i just got a 2000 b20z crv motor I was wondering if this pressure plate will work with the 97 ls tranny and through out berring also will my ls starter conflict with the crv flywheel. I hope they are all the same
Old Mar 20, 2004 | 09:47 AM
zensoku207's Avatar
Pretty sure they are. Any b-series tranny will bolt up an any b-series block, so chances are the pressure plates/bearings are all the same size.
Old Mar 20, 2004 | 11:49 AM
Sliced Beard's Avatar
Default Re: (zensoku207)
all b series flywheels, pressure plates and pilot bearings are the same
the only difference is of coarse tha cable clutch TOB and pre 92' b series engines have a smaller spline input shaft on the tranny
92-01 b series clutch, pp, PB and flywheel IDENTICAL(the TOB is only different throught those years on the 92-93 tranny)
Old Mar 20, 2004 | 10:42 PM
highcomp's Avatar
Default Re: (dirtyd463)
thanx guys I'll let you know how it works out.
ganjasnack
Transmission & Drivetrain
Aug 4, 2010 11:24 AM
thedudefromjerz
Aug 1, 2008 09:54 PM
spidermancivic
May 1, 2005 08:25 PM
phrasathane
Feb 10, 2004 05:48 AM
3rdGteg
Nov 8, 2002 09:50 PM
