What to look for when buying a GSR
Old Mar 20, 2004 | 09:12 AM
CHiPZ's Avatar
Default What to look for when buying a GSR
Looking into buying a GSR in the next few months, 94-99, 2 door, 5 spd.
What to look for, what is the pros & cons. Will be a project car and a daily driver to start. Mod plans are the norm headers, exhaust, intake, chip - then I'll work up to cams, etc.. to work with a turbo after a few years.
Thanks in advance,
Shawn
Old Mar 20, 2004 | 10:13 AM
Zunger's Avatar
Default Re: What to look for when buying a GSR (CHiPZ)
rawr, ill give you a bump as im new to the forum and about to buy a 95 gsr sedan..might be a little curious on what people say.
Old Mar 20, 2004 | 10:18 AM
bboynekro's Avatar
you can basicly tell alot just by driving it in the condition its in, if your going turbo you should hope for low miles
Old Mar 20, 2004 | 10:39 AM
Kendall's Avatar
Give it a compression test before you make any decisions.
Old Mar 20, 2004 | 11:54 AM
ryanmartini's Avatar
Default Re: (Kendall)
theres alot of gsr's that people buy for comuters. try to lock into one of those! also, if it has miles, rebuild it but the gsr engine is very strong, so just check it out and ask questions. have some cash to take it to get serviced after u buy it.
Old Mar 20, 2004 | 12:01 PM
civicbro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Give it a compression test before you make any decisions.</TD></TR></TABLE>
Old Mar 20, 2004 | 12:07 PM
Drian's Avatar
Check for any rust, compression, frame, age of owner helps....carfax would be on the top of the list also. Good Luck
Old Mar 20, 2004 | 02:45 PM
ShayneBishop's Avatar
What are good #'s should be looked for?
Old Mar 20, 2004 | 02:54 PM
cjohnson_2's Avatar
Default Re: (ShayneBishop)
200ish the higher the better
Old Mar 20, 2004 | 04:45 PM
lkshs123's Avatar
Default Re: (cjohnson_2)
Check the radiator, check for paint differences, whether its been modded or not, carfax, how the engine sounds
Old Mar 20, 2004 | 08:46 PM
CHiPZ's Avatar
Default Re: (ryanmartini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanmartini &raquo;</TD></TR><TR><TD CLASS="quote">theres alot of gsr's that people buy for comuters. try to lock into one of those! also, if it has miles, rebuild it but the gsr engine is very strong, so just check it out and ask questions. have some cash to take it to get serviced after u buy it.</TD></TR></TABLE>
how many miles before it should be considered to rebuild.
Old Mar 21, 2004 | 11:47 AM
ofl's Avatar
ofl
Default Re: (CHiPZ)
a gsr that has been kept in running condition and has had the oil change is a good investment. A gsr with 100k on it and has had the oil changed religously is just being broken in.
Old Mar 21, 2004 | 12:11 PM
B18CRacer's Avatar
Im the type that would only buy if i has never been modified with any aftermarket parts. Take a couple test drive and if you get a awesome deal....get it. ITR's prices are dropping, if you are interested in a type r.
jimmyrab
Feb 22, 2008 02:46 PM
jordan_civic
Jan 17, 2008 07:53 PM
boston's_rex
Jun 5, 2006 03:35 PM
wade95gsr
Jan 29, 2006 06:46 PM
CrazyModGSR
Dec 16, 2003 12:48 AM
