GSR & ITR intake air boxes
How can you tell the difference between the ITR and GSR intake boxes and hoses? Does the ITR have a wider diameter? Is the ITR filter element different than the GSR's, and would the ITR filter fit right into a GSR box?
TIA for any knowledgeable responses.
The intake housing itself should be the same. The pipe from the Throttle body to the Box should be different due to the thorttole body locations. The part that makes the ITR intake any better than the GS-R is attached to the resonator. Instead of picking up air from the enging bay like the GS-R, the pickup is turned 180 degrees from a GS-R and picks up air inside the upper fenderwell...
Jason
Jason
KevronsEG
Dec 12, 2002 11:15 AM
