need help! changing valve cover gasket
Old Mar 19, 2004 | 09:53 PM
lvbuckeye's Avatar
Default need help! changing valve cover gasket
well, i pulled the valve coover off no problem. i made a little chart to keep track of all the little nuts and bolts so that i put them back on the the right place, but now i have a problem:
when i went to put the new spark plug seals in (which was the reason for pulling off the cover in the first place), i noticed that the originals were completely round, while the new seals have two divots 180 degrees from each other, on the inside of the 'ring'....
i have a JDM B16A from a '91 Teg, and when i went to Honda, i just ordered the gasket and seals for a '99 Civic Si... should i just leave the old seals in there, or will the ones with the divots be okay?
sorry, but this is the first time i've done anything other than oil/ sparkplug/ brake pad, etc. changes...
thanks!
Old Mar 19, 2004 | 10:09 PM
^jefs0ng's Avatar
Banned
I thought the seals needed replacing? So wouldn't it not be okay to leave yours in there?
Old Mar 19, 2004 | 10:14 PM
lvbuckeye's Avatar
Default Re: (^jefs0ng)
yeah, but i don't want to compound the problem by putting in seals that won't work... the reason that i wanted to change them was that i was getting a little oil on the #3 plug... if the divots allow oil to get past them, then this little project is a waste...
maybe i should just put the new ones in and drive it a bit to see if they work?
-edit-
anyone? anyone?
Old Mar 19, 2004 | 10:24 PM
^jefs0ng's Avatar
Banned
Why don't you just ask a honda service place?
Old Mar 19, 2004 | 10:32 PM
lvbuckeye's Avatar
i'm pretty sure that they are closed right now... thanks anyway.
besides, when i told the guy that i was running a JDM B16A in a '90 CRX, he looked at me like i was talking Greek. the guy was clueless... whatever... i guess i'll just put the new ones in and wait to see if i am still getting oil on the plugs... it's not like it isn't happening already...
Old Mar 24, 2004 | 03:10 PM
lvbuckeye's Avatar
Default Re: (lvbuckeye)
bump.
well, i changed the grommets or sparkplug seals, or whatever the hell they are called, and changed the valve cover gasket last friday...
today i checked the #3 plug, and there is oil on it again! WTF!!?? it doesn't blow smoke or anything, and pretty much runs very well, but this is pissing me off! does anyone know if i should go and get the seals for a VTEC Del sol, or what? i'm gonna go check the other plugs right now, so i'll update in ten minutes or so...
-edit-
well, the other three plugs are pretty much clean, there was a tiny bit on the #1 plug, but 2 ond 4 looked like they just came out of the box...
#3 is the problem... what the hell do it do to fix it? note, it's not so much on the threads, it's on the TOP of the plug where the wire goes...???
PLEASE HELP!
Modified by lvbuckeye at 12:21 AM 3/25/2004
Old Mar 24, 2004 | 03:34 PM
91civicEX's Avatar
did you clean your wires off before you put em back? could just be old oil thas gettin on ur p[lugs
Old Mar 24, 2004 | 03:43 PM
crx_88_si's Avatar
Default Re: (91civicLX)
valve guides?
Old Mar 24, 2004 | 04:32 PM
lvbuckeye's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">did you clean your wires off before you put em back? could just be old oil thas gettin on ur p[lugs
i thought i did... went and cleaned the plug wires, and ran up the street and back... got on it a bit as well... then checked again... everything apppears clean...
damn...
**feels like a dumbass**
gr8gatzby
Nov 11, 2006 08:35 AM
miksew
13
Oct 20, 2006 05:48 PM
RaceMyGhost
Jul 7, 2006 11:03 AM
ludesleeper
Feb 21, 2003 12:10 PM
One2chi
Jan 31, 2003 05:16 AM
