coolant leaking head gasket = lower compression?
Old Mar 19, 2004 | 03:38 PM
hellas's Avatar
Default coolant leaking head gasket = lower compression?
will a coolant leaking head gasket show up on a compression test?
meaning, lower compression on the leaking cylinders
assuming this is the only problem, will the coolant eventually mix with the oil? or will it just get burnt?
thanks
Old Mar 19, 2004 | 04:02 PM
Chiovnidca's Avatar
Default Re: coolant leaking head gasket = lower compression? (hellas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hellas &raquo;</TD></TR><TR><TD CLASS="quote">will a coolant leaking head gasket show up on a compression test?
Yea, if it's pretty bad. A leakdown test is better at showing them.
F Bomb
Jan 31, 2008 06:39 PM
smash fascism
Oct 27, 2006 12:38 PM
97itr86
Oct 30, 2004 08:51 AM
Racerage1
Oct 17, 2003 04:15 AM
Chubz
Jul 1, 2003 02:50 PM
