Can an 89 Crx fit an H22a engine?
Old Mar 19, 2004 | 02:31 PM
delswol's Avatar
Default Can an 89 Crx fit an H22a engine?
Can an 89 crx fit an h22a engine if so will i be able to fit a turbo?
Old Mar 19, 2004 | 02:42 PM
Fred n J_v2.0's Avatar
Default Re: Can an 89 Crx fit an H22a engine? (delswol)
https://honda-tech.com/zerothread?id=711900
hasport is also coming out with a mount kit sometime soon...
but to answer your question, yes it will fit, but for right now, it will require a lot of time, work and money
Old Mar 19, 2004 | 02:45 PM
Nocturnal_Lude's Avatar
Default Re: Can an 89 Crx fit an H22a engine? (Fred n J's_1.8's)
Yes, you can...but there is alot that goes into that conversion...mounts to name one, and another being the massive suspension change. You will be comes a 1/4 mile monster who cant take a turn over 30 if you dont bump up the suspension with the motor. SO...i hope you got cash in hand to spend, other wise you might be better off going GSR or b16
Old Mar 19, 2004 | 03:15 PM
Full Race A6's Avatar
Default Re: Can an 89 Crx fit an H22a engine? (StripShowHatch)
^^ Did you read that somewhere or you know first hand?
Ive seen 2 h22a swaps into ef's and one was lowerred on skunk2 coils and the other on stock complete suspension.
2point2 even said his car is fine, dont preach what you dont know.
When hasports kit comes out its gonna be expensive but well worth it
EDIT: I dont think a turbo h22 would be to easy. You MIGHT be able to fit it with a small rad and a hacked crossmember but pushing over over 300whp in a crx, traction would be almost non existant for you on the street
Old Mar 19, 2004 | 03:58 PM
2point2's Avatar
Default Re: Can an 89 Crx fit an H22a engine? (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">I dont think a turbo h22 would be to easy. </TD></TR></TABLE>
Lotsa room! you can't use the stock CM anyway.
Old Mar 19, 2004 | 04:00 PM
brent_G's Avatar
Default Re: Can an 89 Crx fit an H22a engine? (2point2)
^^^^^ just pm that guy with any questions.
zenon8890
Feb 27, 2007 12:05 PM
smile
Nov 18, 2006 10:28 AM
JDMThoughts
Dec 13, 2004 11:16 AM
AROD
Aug 9, 2004 05:08 PM
MXPX
11
Jul 5, 2001 03:31 PM
