Can a Crx have an H22 engine swap?
Old Mar 19, 2004 | 02:25 PM
delswol's Avatar
Default Can a Crx have an H22 engine swap?
can a crx have an h22 engine swap if so will it be able to fit a turbo?
Old Mar 19, 2004 | 02:28 PM
b_jamin's Avatar
Default Re: Can a Crx have an H22 engine swap? (delswol)
prepare to spend major cash $$$
Old Mar 19, 2004 | 02:46 PM
trusttuned's Avatar
Default Re: Can a Crx have an H22 engine swap? (b_jamin)
i've seen it done, guy made his own solid mounts for it....and no did not spend major cash....as for turbo...VERY hard to fit almost no room at all
Old Mar 19, 2004 | 03:51 PM
mattssi's Avatar
You can get a h22 turbo in there, but there is alot of fabrication work to make it all fit and work properly, and at the end of the day, you have a heavy *** motor in a light car! It will never corner the same!
Old Mar 23, 2004 | 11:48 AM
Mrock's Avatar
Default Re: (mattssi)
Since there's no room for a turbo (although a few people are trying it) you could build the internals on the H22, then just putting a fairly large shot of nitrous on it..since there's no room to turbo. It'd be very potent. If you have the time and money, more power to you.
Old Mar 23, 2004 | 12:29 PM
MightyMouseTech's Avatar
Default Re: (Morhpeous)
You can do anything as long as you have the $$$$$$$
CoolRedXylophone
Jan 31, 2006 07:59 PM
UNDER PRESSURE
Sep 14, 2005 09:18 AM
contender
Feb 3, 2005 01:21 PM
halcyon
May 13, 2004 01:58 PM
neronian
Mar 28, 2004 12:21 PM
