Exhaust size...
My birthday is coming up on the 25th and i know what i want for it. I am planning on getting a cheap ebay dc style header, a high flow cat and having a muffler shop make me an exhaust. I was wondering what size exhaust a prelude has stock. I was thinking of having a muffler shop make me an exhaust made of 2.5 inch mandrel bent piping to my muffler (i already have it). Now is 2.5 too big? i have heard yes and no and i just want to hear from all you fellow luders out there...
If your having a muffler shop build you an exhaust and you already have the muffler then I'd say go with the 2.5" piping, espeically if the muffler has a 2.5" inlet and outlet. Definitely run the high flow cat and skip the headers. 2.5" piping isn't too big, it's just about right. If your motor is mainly stock than 2-1/4" -to- 2-3/4" is just about right. My Invidia N1 Stainless Cat-Back for my '01 Prelude Base is of the 60mm tubing or 2.36". I'd imagine they chose that size for a reason. The key is high flow while maintaining the right back-pressure in the system. You may want to consider the idea of whether or not to run a resonator. A resonator usually quiets down the sound a fair amount, but again, flow and back-pressure change as well. A high flow cat isn't gonna add 20hp but keeping a cat is a good idea for the earth, emissions and the fact that no cat would set off a check engine light, so for the money, going high flow is a good idea there. Headers, not worth the money in your case. The only time headers are necessary are when you are building a naturally aspirated engine for peak power and money is no concern. It takes a very well designed, high end header to make any kind of power and cheap eBay headers are not gonna be worth it. Don't get me wrong, on a $12k N/A build, with computer aided design and testing, you can build a $1,000 set of headers and add like maybe 15-20hp IF TUNED. I had a set of actual DC Sports headers on my f22b1 in my '94 Accord and they cracked along the welds like a mother f'er, on at least 3 separate occasions. Good fabrication costs good money,
You may not want to hear it but its worth saying, you may want to consider just buying an aftermarket stainless cat-back designed for your car, maybe even a used system if your tight on cash. If you already have a muffler, maybe you could sell it. Having a muffler shop mandrel bend, weld and fit a complete custom system isn't a bad idea, its actually kind of cool and I might do the same, it's like getting a chance to have something built from your taste, specs & under your terms but I'm just sayin for the $, you might end up spending more having the shop build it, but if thats alright with you then, hey
JDubya
Jan 4, 2005 04:51 PM
thinkbrianthink bu
Honda S2000
Oct 1, 2003 12:02 PM
