Went to the Drag strip tonight...
Old Oct 21, 2001 | 12:44 AM
Austin's Avatar
Default Went to the Drag strip tonight...
So I decided to make the 100 mile trip to the closest open drag strip...Sacramento, Ca, it was around 60 degrees at the end of the night.
Car weight was just a hair over 2700+ with me in it...full interior, need to remove some weight
Car was running on 91 octane, with 205-45/15 Nitto NT-555R tires(2 years old) on stock rims, back tires were 215-45/16.
Dyno curves, and modifications are listed in my signature.
Time1...2.112
Time2...5.963
Time3...9.116
mph3...78.690
Time4...11.810
1/4...14.105
mph...99.972
Time1...2.194
Time2...5.939
Time3...9.058
mph3...79.536
Time4...11.728
1/4...14.008
mph...99.945
<u>Best Time</u>
Time1...2.179
Time2...5.899
Time3...9.004
mph3...78.275
Time4...11.666
1/4...13.940
mph...98.001
Time1...2.227
Time2...5.987
Time3...9.105
mph3...77.799
Time4...11.781
1/4...14.061
mph...97.642
Time1...2.401(tried different launch rpm...spun tires)
Time2...6.145
Time3...9.250
mph3...78.132
Time4...9.250
1/4...14.189
mph...97.890
Time1...2.273
Time2...5.995
Time3...9.098
mph3...78.213
Time4...11.760
1/4...14.027
mph...98.180
Time1...2.238
Time2...6.046
Time3...9.168
mph3...77.815
Time4...11.839
1/4...14.118
mph...97.645
Old Oct 21, 2001 | 12:56 AM
Rhetoric's Avatar
Default Re: Went to the Drag strip tonight... (Austin)
Great times for having 2700lb. Are the dyno graphs from DSR/Comptech the most recent? I think you had 191 to the wheels? What were you launching at?
Old Oct 21, 2001 | 01:12 AM
Austin's Avatar
Default Re: Went to the Drag strip tonight... (G S R)
The dyno's are recent...so I'm at 191 at the wheels...but that was with an alternator putting out 13.5 volts, not sure if there would be much of a differnce since I fixed it.
Launching at 4000, 4500, 5000, 5500...I had best results at 4000, and 4500, anything higher and I'd just spin the tires, which happened to be inflated to 17psi cold, around 20 psi after the run.
Time to go to bed...have to leave in 5 hours
Austin
Old Oct 21, 2001 | 06:55 AM
Louie's Avatar
What would Chente do?
Good job Austin!..i'm jealous. My best is currently a 14.2...jerk! jk
Anyway, nice runs there. Btw, whats your next step, powerwise?
Old Oct 21, 2001 | 12:01 PM
Type R's Avatar
how much was your hitech exhaust?
Old Oct 21, 2001 | 07:24 PM
Austin's Avatar
Default Re: Went to the Drag strip tonight... (Type R)
THe header was $1300...his cat-back does not yet have a final price.
Austin
Anyone want to halp me analize these times? Anywhere for improvement?
Old Oct 21, 2001 | 09:04 PM
SpeedRacer00-667's Avatar
NIce run & consistency, i only did 14.0 twice and can't get those times anymore, but i only had a cat-back, nittos slicks and back seats & spare out
AnyWays, Congratulations to another R in the 13's
later
Old Oct 22, 2001 | 11:59 AM
YodaIsGod
Guest
Posts: n/a
i said once, and I said it again...
YOU ***
Old Oct 22, 2001 | 12:02 PM
Chris's Avatar
Default Re: Went to the Drag strip tonight... (YodaIsGod)
fugger....I want to get a 13 too!! Next time at Sears Point, dont forget your helmet!
GREAT JOB!
Old Oct 22, 2001 | 12:04 PM
MPH's Avatar
MPH
New User
What is the elevation of that strip?
Old Oct 22, 2001 | 12:33 PM
YodaIsGod
Guest
Posts: n/a
well....betcha you can't bowl 130!!! hehehehe
Old Oct 22, 2001 | 01:11 PM
Austin's Avatar
Default Re: Went to the Drag strip tonight... (MPH)
It is near Sea Level.
I just did some computations, and if this engine was in a 1600 lb track only drag car it would be around a 11.6...now imagine if it was a drag only engine But then again they are only mathematical figures.
[Modified by Austin, 2:19 PM 10/22/2001]
Old Oct 22, 2001 | 01:14 PM
Black SVT's Avatar
I ran similar times on street tires with just an intake and header(in my sig)I just pulled a lot of weight out.You should take all of the "useless" stuff out of the car.Those are really impressive times, esspecially considering it has full interior
Old Oct 22, 2001 | 01:24 PM
thefungus's Avatar
New User
Time1...2.194
Time2...5.939
Time3...9.058
mph3...79.536
Time4...11.728
1/4...14.008
mph...99.945
<u>Best Time</u>
Time1...2.179
Time2...5.899
Time3...9.004
mph3...78.275
Time4...11.666
1/4...13.940
mph...98.001
took a close look at it and it
seems there was almost 2mph
difference in those two runs.
with, very little difference in
60ft times. no idea what that
means just thought i'd point
it out.
Old Oct 22, 2001 | 01:30 PM
Austin's Avatar
Default Re: Went to the Drag strip tonight... (theFungusAmongus)
The only thing that I can say is that I most likely shifted at a slightly different point, as without a shift light or an accurate tach it is difficult to shift at the same rpm point every time.
Austin
Old Oct 22, 2001 | 01:39 PM
Austin's Avatar
Default Re: Went to the Drag strip tonight... (Chris)
GREAT JOB!
I had the helmet sitting on the passenger's floor...never put it on...though next year I will be wearing it so that I don't get a DQ if I have a free run.
Old Oct 22, 2001 | 01:40 PM
Austin's Avatar
I can if I have the money to spend on bowling...
Old Oct 22, 2001 | 02:21 PM
YodaIsGod
Guest
Posts: n/a
riiiiiiiiiight!!! I just think you are not good at it.
Old Oct 22, 2001 | 02:22 PM
Austin's Avatar
If you're paying next week...
CaliforniaDad
Jan 3, 2014 01:28 PM
Jason703Racing
Apr 13, 2008 07:10 AM
Justin Olson
Dec 28, 2005 01:06 PM
codeh22a4
Apr 30, 2005 07:48 PM
TypeR1558
Sep 6, 2002 09:23 PM
