Gm synchromesh is same as other brands. (link)
Old Mar 19, 2004 | 12:59 PM
InfamousGSR's Avatar
Default Gm synchromesh is same as other brands. (link)
Here is a link. Check out last paragraph.
http://www.stealth316.com/2-pe...h.htm
Old Mar 19, 2004 | 01:15 PM
Default Re: Gm synchromesh is same as other brands. (InfamousGSR)
Sucky part is, its not friction modified.
Old Mar 19, 2004 | 01:17 PM
purplegsr's Avatar
You don't need the FM Syncromesh if you aren't running a LSD. The Friction Modifiers are designed to reduce chatter in LSD equipped gearboxes, but some think it is too slick for non-LSD trannies. So anyone without an LSD, like me, can buy Pennzoil to their heart's content.
Old Mar 19, 2004 | 01:40 PM
Xymox007's Avatar
Default Re: Gm synchromesh is same as other brands. (purplegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">You don't need the FM Syncromesh if you aren't running a LSD..</TD></TR></TABLE>
I swear by GM Synchromesh, as do many others. my 4th to 5th gear grind slowly vanished after running GM Synchromesh. This stuff is the sweet sauce.
sucks because I have a quaife.
Old Mar 19, 2004 | 01:46 PM
purplegsr's Avatar
Ahhhhhhh, Soorrrry homie. At least you get better traction than me!
Old Mar 19, 2004 | 01:48 PM
purplegsr's Avatar
Default Re: Gm synchromesh is same as other brands. (Xymox007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 &raquo;</TD></TR><TR><TD CLASS="quote">
I swear by GM Synchromesh, as do many others. my 4th to 5th gear grind slowly vanished after running GM Synchromesh. This stuff is the sweet sauce.</TD></TR></TABLE>
I didnt say I don't use Syncromesh, I am just saying that there are 2 types (friction modified and non-friction modified). If you have to use FM due to having a LSD like InfamousGSR, then you can't use the Pennzoil version. However, if you don't have an LSD, you don't need to use the FM version, and can use plain old GM, Quaker State, pennzoil syncromesh and save a little money for the same product.
sonny0330
May 10, 2008 12:00 PM
kamAccord
Mar 8, 2007 06:05 AM
riceburners1
13
Jun 26, 2004 08:52 AM
civicSIracer96
Nov 20, 2003 04:44 PM
TeamSTEALTH GSR
May 21, 2003 09:17 AM
