LS in EG Fuel Problems
Old Mar 18, 2004 | 10:41 PM
rxse7n
Guest
Posts: n/a
Default LS in EG Fuel Problems
I swapped an LS in my EG a couple months back and ever since, whenever I try to go full throttle in second, third, and sometimes forth gear the motor nearly dies around 5k-6.5k RPM's. I assumed it may be a number of promblems, but finally today I got my A/F gauge installed. It goes all the way lean when this happens, so obviously my engine is starving for fuel. Where do you think I should start? There is still the little DX fuel pump in there because I just moved and I cannot find the LS one I want to install. Should I check out the fuel filter? Possibly bad injectors? What do you guys think?
Old Mar 19, 2004 | 08:35 AM
JDM-Vic's Avatar
bump for a good question
Old Mar 19, 2004 | 09:35 AM
colt45.5's Avatar
Default Re: (JDM-Vic)
Wouldnt hurt changing the fuel filter.
Ive used dx pump on my b18c1 hatchback and had NO PROBLEMS.
Who knows. It could be bad, anythings possible.
What ecu are you running?
Do you have any trouble codes?
thewhite_ricer
11
Jun 5, 2009 06:54 AM
B Series JuNky
Jul 20, 2007 10:27 AM
conceptEG
Nov 23, 2006 09:24 AM
speeddave
24
Feb 5, 2004 08:27 AM
speeddave
Jan 26, 2004 09:25 AM
