The mysteriouse clunking. NEED SOLUTION!!!
Old Mar 18, 2004 | 10:07 PM
es_squared's Avatar
Default The mysteriouse clunking. NEED SOLUTION!!!
lol ok, ive had this problem ever since i got my lude and its farkin annoying ! Anyway the noise/clunking/thumping sounds like its coming from the rear passenger suspension. i can hear/feel it when i go over bumps and potholes in the road.
Anways ive tried pretty much everything, ive goten a new strut, new bushings, checked the strut mount, checked the strut mount colar bushing etc. I dont know wtfffff it is. Except one thing, the upper control arm bushing sleeves in that corner are shaped differently than the ones on the other corners.. but i dont know. also could it be the endlinks(stock) on my sway bar?
HELP!? This is on a 93 Prelude srv btw.
Old Mar 18, 2004 | 11:01 PM
suspendedHatch's Avatar
Default Re: The mysteriouse clunking. NEED SOLUTION!!! (es_squared)
check the swaybar mounting in great detail. replace the swaybar bushings with urethane while youre at it, and get some upgraded end links.
Old Mar 18, 2004 | 11:27 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: The mysteriouse clunking. NEED SOLUTION!!! (shaundrake)
Make sure all bolts are tight on the top. Make sure all bolts are tight on the bottom. Bounce up and down on the ride, locate the clicking. Did it happen all of the sudden?
Old Mar 19, 2004 | 01:12 AM
preludevtec7's Avatar
Hi there
I get exactly the same problem in my 95 prelude. I've been told by a honda mechanic mate of mine that its very likely the ball joint in the top arm of the suspension. You'll need to get a new kit to replace this, which I will be doing as soon as! Have you had the car lowered too? When I had mine done the problem went away, but now its back and I was told its from the ball joint wearing away in its socket again. A quick test is to shake the wheel to and fro and if you get the knock you'll know its that!
Hope you get it sorted!
A
Old Mar 19, 2004 | 10:18 AM
es_squared's Avatar
Default Re: The mysteriouse clunking. NEED SOLUTION!!! (preludevtec7)
ok thanks guys, and ya my cars lowered on KYB AGXs and H&R race springs. its been happening ever since i got my lude, since it was stock hehe.
but ill give what you guys said a go too
BigChina
Apr 18, 2009 08:21 PM
IntegraBoy04
Apr 26, 2005 12:04 PM
NtegraDryvr
Jan 18, 2005 09:20 AM
es_squared
Apr 9, 2004 03:59 PM
BoostedGSRBubble
Nov 4, 2003 05:04 AM
