What do I used to clean out my itr head......
I just bough a new type r head and its has all kinds of things inside of it. I wanted to know what to use to clean the head.....
if you disassemble it you can use parts cleaner (varsol) solution. It would be a good idea to thoroughly lube the valve stems , and internal parts prior to installing the head on the engine, it doesn't take long to damage a valve guide if the parts are dry.
J.
J.
civicracer1993
May 16, 2003 12:20 AM
