How much for a complete b20vtec???
Old Mar 18, 2004 | 06:16 PM
JD95hatch's Avatar
Default How much for a complete b20vtec???
im really tryin to get as much info on this engien as possible.....
I would be in the market for a 99 JDM b20b to get that extra hp boost and look to pay around 800 for the long block.
Any info on complete engine price would be awesome...thats what i really need
Old Mar 18, 2004 | 06:42 PM
Kendall's Avatar
If you are referencing a physically complete engine and already have a B series engine in your car, then you'll just need the longblock, if you want a complete swap you'll just have to buy an LS or B16 complete swap, and then buy the B20 longblock.
Old Mar 18, 2004 | 06:46 PM
JD95hatch's Avatar
Default Re: (Kendall)
so its gonna cost a good 3-4k for a complete b20vtec...then i could sell of the b16/b18 block and other componets unused.
Is the vtec gain worth it?? what kind of potential does a b20 have non vtec....ive seen some numebrs but cant remember if it was NV or V but with a few bolt ons it was running 170+whp 150tq
Old Mar 18, 2004 | 06:52 PM
Kendall's Avatar
Personally, I wouldn't even consider running this setup without having it properly built from the get go. In order to really take advantage of the rev potential of the B series head, you'll have to have the crank balanced, and run lighter and better balanced forged internals. You should also take the opportunity to raise the compression significantly. If it were me, I'd go ahead and have the block sleeved.
Old Mar 18, 2004 | 07:16 PM
Sliced Beard's Avatar
chad will sell you his fully built b20TEC to you for 6000
endyn rollerwave pistons cams and all
this motor is badass
good for over 220whp
Old Mar 18, 2004 | 07:20 PM
JD95hatch's Avatar
Default Re: (dirtyd463)
money is a lil low...thats why i turned to the b20, because of its low cost, but it seems to get a well prepped b20 you need some cash flow.
with the new b series head...wouldnt that raise the compression up a significant amount?
Old Mar 18, 2004 | 07:52 PM
Default Re: (JD95hatch)
use this link it is your friend
<<<click on the smiley face
using either a b16/b17/ITR head will yield slightly higher compression numbers
(all three of those heads are identical)
and by using a GSR head it will riase it a bit more
j spec
Southeast (Sales)
Dec 12, 2006 10:30 AM
1320DRAGWORKX
Jun 13, 2006 06:47 AM
oxhernandez
Jul 14, 2005 03:04 PM
