B20 crank in Ls???
Old Mar 18, 2004 | 03:22 PM
vteken_y0's Avatar
Default B20 crank in Ls???
ok there have been a few people that have conversed about this , can it be done ????? i nkw it wil bring the stroke up so it should be dissplacement adder shouldnt it ??? anyone here done it ???
Old Mar 18, 2004 | 03:50 PM
mattssi's Avatar
Default Re: B20 crank in Ls??? (vteken_y0)
What a first post. Is this a ***** nilly idea, have your researched this at all? I would look for the simularities between the ls and b20 cranks before making ASSumptions. Welcome to H-T.
Old Mar 18, 2004 | 04:23 PM
Malgerus's Avatar
Isn't it the same thing? I thought the motors were basically identical except for the B20's larger bore...
Old Mar 18, 2004 | 04:49 PM
alj's Avatar
alj
Default Re: B20 crank in Ls??? (Mr. S)
maybe its the old b20a in the prelude 90-91 with a 95mm stroke.
Old Mar 18, 2004 | 05:03 PM
vteken_y0's Avatar
alj- i dont know what crank it is exactly , i dont feel like being flammed here , i just wanted some light shinned on this unclear subject.
Old Mar 18, 2004 | 05:53 PM
Kendall's Avatar
The crank from the CRV B20 engine is identical to the crank from the LS engine. The crank from the Prelude B20A engine has an increased stroke. Yes it's possible to use it, but it really isn't practical. The B20A is already presumed to be hopeless when it comes to modification due to it's horrible rod/stroke ratio. If you do pursue this swap, be sure to have the crank balanced perfectly in every way.
Old Mar 18, 2004 | 07:12 PM
Sliced Beard's Avatar
Default Re: (Kendall)
that and custom rods are expensive
unless you use the weak 20a rods
Old Mar 19, 2004 | 11:42 AM
vteken_y0's Avatar
Ok , well thanks for all the tips , i just wanted to be sure on what it was exactly , thats all
Old Mar 19, 2004 | 11:53 AM
alloutmotor's Avatar
yes you can swap the crank shaft from the older b20a ludes and you will have 95mm stroke, you also can get rods from crower since, they make rods for their 95mm stroker kit, your r/s ratio will be horrible, but u will make alot of down low power and torque, you will be putting alot of wear on the engine because of the amount of load being pushed on the sleeves
in order for your engine to last longer, rev smoother, you will probably have to get a deckplate block, this is where it gets expensive, and this is when u need custom length rods, but over all the engine will be safer
you can make alot of power with that setup if u have a head flowing enough air, but dont try to participate in NHRA races because i believe deckplates are banned
Old Mar 19, 2004 | 02:25 PM
alj's Avatar
alj
b20a crank with rod bearing machined down to b16 size fit perfectly in b18 block with b16 rod.
swirve1
Jan 6, 2010 06:23 AM
Da1spaz247
Oct 1, 2005 08:27 PM
jdm92teg
Apr 13, 2005 01:20 PM
hybridpatient95
20
Jan 4, 2005 05:07 PM
