yet another prob with my b16...need help
Old Mar 18, 2004 | 02:55 PM
91hatch_on17's's Avatar
Default yet another prob with my b16...need help
ok, another problem just started happening. I have a b16 first gen in my 91 std hatch. I had just finished the swap. Car was running fine except that the idle was a little high. Anyways, my tach started jumping up and down like if it was been flicked or something, after it was happening for a while, the car started bogging out. Now its to the point where im driving and the rpms will drop to 0 and it won't go, it won't stall though. I turn it off and back on, and it will run for like 20 seconds then do the same thing. What could be wrong? And now im getting a code 7. Need help.
Old Mar 18, 2004 | 06:38 PM
TwztdSi's Avatar
I believe a code 7 is your Throttle Position Sensor. Try swapping that out for another one. I belive all honda TPS's are the same so it shouldn't be hard to fine one at the local junk yard.
Old Mar 18, 2004 | 07:05 PM
Kasper.'s Avatar
Default Re: (TwztdSi)
Ignitor pal.
Old Mar 18, 2004 | 07:35 PM
Default Re: (Kasper-EF8)
ill try the ignitor first then i'll try the tps. Is there any way to test out the ignitor before changing it.
Anymore feedback? Thanks guys, keep it coming.
Old Mar 18, 2004 | 07:40 PM
icon_race_eg's Avatar
Default Re: yet another prob with my b16...need help (91hatch_on17's)
map tps reset the ecu for 15 sec see if it helps
Old Mar 18, 2004 | 08:13 PM
Default Re: yet another prob with my b16...need help (mac13_34)
i reset the ecu, code 7 went away. Took it out for a spin and it still doing the same thing. I'm going with the ignitor then. Anything else that it could be?
Old Mar 19, 2004 | 04:24 PM
not sure maybe u should go check a shop manual or chiltons at a local store to see what it is if its a sensor itll be there. if not check ignition system and fuel system.
Old Mar 19, 2004 | 06:21 PM
Cory man's Avatar
Just like was said above, its your ignitor. The tach receives a signal from the ignitor and that is a common "symptom" when one goes bad. HTH
Old Mar 21, 2004 | 03:39 PM
Default Re: yet another prob with my b16...need help (Cory man)
what ignitor should I buy for my b16 obd0 dizzy? are the dx and std ignitors different from the SI?
Old Mar 22, 2004 | 12:00 AM
white90crx's Avatar
I had the same problem a while back, have your alternator checked out. That fixed my problem, maybe its yours to. its worth the time and an easy fix.
Old Mar 22, 2004 | 05:19 AM
StupidSlowRSX's Avatar
umm... are you in an EF with this b16? if so, resoider your mainrelay, easy/cheap fix
Old Mar 22, 2004 | 05:47 AM
Cory man's Avatar
Default Re: (StupidSlowCRX)
You can use an ignitor from any 88-91 Civic or 90-91 teg. Buy OEM new so you will know this part wont fail. BTW autozone,pep boys ignitors are JUNK! Buy one and I guarantee within a yr it will have failed.
Old Mar 22, 2004 | 02:30 PM
Default Re: (Cory man)
yeah, ef b16, ok, took it to the shop. Told me my tb was messed up so they changed it and they changed the ignitor, but the tach is still jumping around sometimes. Car is running now. Only sometimes it feels like it bogs.
project91crxsi
58
Aug 31, 2009 06:22 PM
jonezen1
Aug 23, 2007 07:20 AM
2ner12sec
Jun 24, 2005 10:27 PM
^MikeG
Nov 25, 2004 11:30 AM
1.8Tities
Mar 6, 2003 08:17 AM
