Compression and smog 2 question
My first question is, does compression effect your emissions? I am pretty sure it does but im just asking to set a base for my next question
If i changed my pistons to run around 11.5:1 (CA shitty gas) and i came time to do smog check could i put 2 or even 3 oem head gaskets on to lower my compression enough to pass smog? this may seem like a bad idea to most but for the simple intent of going down the street and back would it cause a problem? and better yet would it work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul »</TD></TR><TR><TD CLASS="quote">My first question is, does compression effect your emissions? </TD></TR></TABLE>
Higher compression = higher NOX during loaded mode testing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by visi0n »</TD></TR><TR><TD CLASS="quote">get your ecu tuned...make sure your cat is working and you should pass regardless of compression ratio.
Compression does affect NOx emissions. I find that anything over 12.5:1 CR will be very hard to pass and require major tweaking to the ign, cam timing and fuel maps. A functional (and preferably piping hot during E-test) catalyic converter is a must.
_inline4turbo_
Apr 30, 2009 08:06 AM
