Upgraded headlight wiring harness and higher wattage bulbs
Old Oct 20, 2001 | 02:04 PM
mercury's Avatar
New User
Default Upgraded headlight wiring harness and higher wattage bulbs
Has anyone used this?
http://www.groupbuycenter.com/buy.as...ad&row_id=3469
Is the difference in light output worth it?
Is the extra heat significant enough to cause problems in melting the plastic in the headlight area?
Old Oct 20, 2001 | 02:10 PM
fixhondas's Avatar
Default Re: Upgraded headlight wiring harness and higher wattage bulbs (mercury)
These would really only be beneficial if you are using high wattage bulbs. What exactly is your situation? don't expect much if any increase in brightness- I wouldn't bother with it unless you are experiencing excessive harness heat with high wattage bulbs.
Rok_Stok
Aug 16, 2011 11:06 PM
integracura
Jul 26, 2007 07:48 AM
MuthaFodder
Dec 5, 2005 10:53 AM
hometheaterman
Oct 7, 2004 12:41 AM
EGcivicBoy
12
Apr 2, 2004 03:48 PM
