how exactly do you adjust the TPS?
Old Mar 18, 2004 | 01:07 AM
Unjockable's Avatar
New User
Default how exactly do you adjust the TPS?
did a lot of searching and it says that you use a voltmeter to adjust the throttle position sensor. i'm very stupid with it comes to electronics and such. can someone help me? also, what is it that you're suppose to do with the TPS? just move it around? i dunno...
Old Mar 18, 2004 | 06:25 AM
EE_Chris's Avatar
Default Re: how exactly do you adjust the TPS? (Unjockable)
If you look at the TPS, you'll notice its held on by rivets, or break away bolts I belive they are called. What you need to do is get a Dremmel to slot the rivets in order to use a flathead screwdriver to loosen them up.
What car is this for?
96-00 Civic and 98-00 Integra = Grn/blk is ground, Red/blk is output
92-95 Civic (and I assume 94-97, but I don't have that Helms manual) = Grn/wht is ground, Red/blu is output
With the key-on/engine-off (and idle), you should measure .45v. Now, hopefully you have NOT messed with the throttle plate stop screw....if you have, this directly affects the TPS output and thus needs to be reset before messing with the TPS itself.
Old Mar 18, 2004 | 10:56 AM
Unjockable's Avatar
New User
Default Re: how exactly do you adjust the TPS? (EE_Chris)
i have a 96 civic. where do i measure? the wires that are suppose to conect to the TPS? BTW, i got the TPS off already.
how do u adjust it?
Old Mar 18, 2004 | 11:09 AM
EE_Chris's Avatar
You weren't suppose to take it off, just loosen the screws and rotate.
You can use the wires specified to make your measurement....thats why I gave them to you.
Old Mar 18, 2004 | 01:44 PM
paybac4223's Avatar
If you took it off you will need to adjust the voltage...
http://www.integra.orcon.net.nz/tps
kholmes
Oct 12, 2004 06:59 PM
integra-modder
Jun 6, 2004 07:34 AM
manson
Aug 8, 2003 06:39 AM
realblag
Aug 6, 2003 05:21 PM
