5 wire to 4 wire o2 sensor help
hi, i was wondering if anyone knew where a good digram or explanation is on how to to turn my 5 wire o2 sensor to a 4 wire. any help is greatly appreciated!
https://honda-tech.com/zerothread?id=295330 is this any help?
Are you swapping a motor into a vx? Here's my instructions: https://honda-tech.com/zerothread?id=644434
I guess I should explain a little better..
I bought the car and it has a SI swap with a p28 ecu but the VX harness. I want to change the 5 wire to a 4 wire so the cel will shut off and the ECU will run correctly. Any help is greatly appreciated thanks so far guys. If one of those u send works for what I am doing please let me know. Thank u
SPOON_BeIgHtEeNsEe
Mar 3, 2008 03:26 AM
