code 4 with dohc zc i ran the wires like 3 times still code 4
Old Mar 17, 2004 | 09:43 PM
89HTACH's Avatar
Default code 4 with dohc zc i ran the wires like 3 times still code 4
can it be my ecu thats no good i have a pr4 please help
Old Mar 18, 2004 | 03:57 AM
Filthy Focker!'s Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (89HTACH)
code 4 = CPS
i don't understand what you mean by "ran the wires"
But check all connections from and to ecu and CPS
then measure voltage to cps, start the car and measure signal from cps...
Could be bad sensor or connections...
fs
Old Mar 18, 2004 | 04:13 AM
virginia_dude's Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (filthy_shovel)
or a backwards wired sensor even. Or Cam timing off.
Old Mar 18, 2004 | 05:13 AM
jc836's Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (virginia_dude)
In most cases CODE 4 is the Crank Angle/Position Sensor-which is buried in the distributor housing and not available by itself. TD-02U distributors are also known to have this specific failure. Look inside the cap and on the modules for reddish bearing dust-that is your clue. If all of the wiring for the car is correct then this is likely the problem. (Need a TD-02U-I have one).
Old Mar 18, 2004 | 06:40 AM
jlicrx's Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (jc836)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 &raquo;</TD></TR><TR><TD CLASS="quote">In most cases CODE 4 is the Crank Angle/Position Sensor-which is buried in the distributor housing and not available by itself. TD-02U distributors are also known to have this specific failure. Look inside the cap and on the modules for reddish bearing dust-that is your clue. If all of the wiring for the car is correct then this is likely the problem. (Need a TD-02U-I have one).</TD></TR></TABLE>
incorrect camshaft timing will also cause code 4 - most likely distributor
Old Mar 18, 2004 | 07:18 AM
turbo89civicb18hatch's Avatar
u need to make shure u have the cps hooked up right to the ecu. the sensor is at the distributer side of the exhaust cam on a zc.
Old Mar 18, 2004 | 10:41 AM
89HTACH's Avatar
Default Re: (turbo89civicb18hatch)
hey were do u live can anyboddy help me out i live near long beach i will pay not alot dont really have money but please help
Old Mar 18, 2004 | 12:18 PM
RobbieG35's Avatar
12 Years Strong
Default Re: (89HTACH)
Code 4 still owns me, 3K rev limitor
Old Mar 18, 2004 | 05:46 PM
89HTACH's Avatar
Default Re: (HybridHatch88)
me too dont trip mine goes to 4200
Old Mar 18, 2004 | 06:17 PM
USDM 4G VTEC's Avatar
right click and save as the pictures , then use ur paint program to zoom.... imagestatin resize them for their site
anyways make sure the B10 and B12 cables are actually on the right spot on the harnes... basically the harness orange to B10 and white to B12..
and C1 and C2 to the engine bay for CYL sensor (not the case)
Old Mar 18, 2004 | 06:48 PM
crxgator's Avatar
A Blue
B Blue/Yellow
C White
D White/Red
E Peach
F White/Blue
G Peach/Blue
make sure your wiring is exactly like that...
Old Mar 18, 2004 | 07:47 PM
icon_race_eg's Avatar
4 is map. its mechanical not eletrical. check hoses intake manifold gasket and head. 3 is map eletrical 4 is mechANICAL i think
Old Mar 18, 2004 | 10:57 PM
89HTACH's Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (mac13_34)
i need someone to do my wirring were can i take my car im near long beach please help
Old Mar 19, 2004 | 03:55 AM
RZcHatch's Avatar
your code 4 is because your cam angle sensor is bad. the person I work with at my friends shop has a dohc zc in his 4door and it was throwing code 4 all day everyday. So i suggested to check the cam angle sensor. Well I was right it was bad. you need to change the cam angle sensor. Its not that much money and very easy to do. 20 min 30 tops.
Old Mar 19, 2004 | 05:57 AM
crxgator's Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (RZcHatch)
no its crank angle sensor...its not cam...helms manual has already been posted...he needs to check his wiring with the diagaram i posted first...
Old Mar 19, 2004 | 06:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac13_34 &raquo;</TD></TR><TR><TD CLASS="quote"> 4 is map. its mechanical not eletrical. check hoses intake manifold gasket and head. 3 is map eletrical 4 is mechANICAL i think</TD></TR></TABLE>
u sir dont know what u say
MAP sensor is either Code 3 or 5
Code 4 is crank angle sensor
your kinda posts are what confuses all these newbies wanting the actual fact correct information
Old Mar 19, 2004 | 06:21 AM
crxgator's Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
your kinda posts are what confuses all these newbies wanting the actual fact correct information</TD></TR></TABLE>
for realz...
Old Mar 19, 2004 | 04:20 PM
didnt know the zc was differnet from a6 sorry newbies
Old Mar 19, 2004 | 04:39 PM
XEF-9X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89HTACH &raquo;</TD></TR><TR><TD CLASS="quote">i need someone to do my wirring were can i take my car im near long beach please help </TD></TR></TABLE>
my guy is way good.
Japanese engine & repair in garden grove
hes awesome. hell prolly charge you around 50 bucks
Old Mar 19, 2004 | 05:00 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac13_34 &raquo;</TD></TR><TR><TD CLASS="quote">didnt know the zc was differnet from a6 sorry newbies </TD></TR></TABLE>
wtf...who are you calling a newbie...your answer was completely wrong...watch what you say...
Old Mar 19, 2004 | 05:49 PM
Kasper.'s Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (crxgator)
Man dont get all worked up act like the member you are, dedicated and experienced......cough cough mature....
Id still go back at your wiring, its easy to mess up the wiring for the distributor since the wires look similiar in color look to make sure you didnt hook the wrong one up due to faded colors.....lol sounds dumb but it happens more then you think.
Old Mar 20, 2004 | 02:07 PM
silver89civic's Avatar
Where can I buy the cam sensor? I've been going to the junkyards but I haven't had luck at all
Old Mar 20, 2004 | 04:53 PM
89HTACH's Avatar
Default Re: code 4 with dohc zc i ran the wires like 3 times still code 4 (XEF-9X)
were is he located in do i tell him u send me or what i was thinking off taking my dash out and replacing all my wirring harnest with an si i saw the harnest at the junk yard it was actually out off the hf crx would that work
superslowcrx91
Sep 30, 2013 12:54 PM
JdM_RACeR07
Nov 27, 2006 10:22 AM
Ekay Jay
18
Jun 24, 2004 10:06 PM
EF'n
Aug 20, 2002 01:11 PM
Cereal_Killer
Jan 23, 2002 04:58 AM
