motor swap
Old Mar 17, 2004 | 04:29 PM
starbury's Avatar
Default motor swap
i swapped a 00 si into my 99 ex, everything was going fine and for the most part still is. the only 2 problems i had was when it snowed one day i was driving the car and i saw that smoke was commin from under the hood, it looked like it was commin from the radiator or in that area. i loosened the hose clamp a slight bit and after drivin around a little bit it stopped, and i never figured out what was wrong. now my temp needle seems to be holding in the little bit over half way mark on warmer days but not by a lot and it stays at half way point on cold days. do i need a new radiator to run this swap? or am i just being paranoid? and if i do what is a good radiator that has oe fitments and can use all the same hoses and fans
Old Mar 17, 2004 | 04:32 PM
Smith Wise's Avatar
Default Re: motor swap (starbury)
99 y8 to 00 b16a2 should require an immeadiate radiator upgrade... if I were you I'd do a flush and fill and just monitor it...
jameskersten1's Avatar
edit. nevermind
Old Mar 17, 2004 | 04:34 PM
starbury's Avatar
another problem i had in the begining was the coolant was draining real quick, i was filling it about every3 days
Old Mar 17, 2004 | 04:51 PM
Mr Boston's Avatar
Are you sure your not leaking collant anywhere?
Old Mar 17, 2004 | 05:00 PM
starbury's Avatar
Default Re: motor swap (Clicky Pow)
yeah, i park the car in the garage and the floor is spotless
Old Mar 17, 2004 | 05:06 PM
ImportMotorSpec's Avatar
Find a shop that has a radiator compression tester and put it under pressure. There has to be a leak somewhere, external or internal. Hopefully it is external. If it is loosing pressure and no external leak, good luck...
93grayeg
25
Feb 21, 2012 05:07 AM
LEGiTLUDA
13
Nov 27, 2011 05:40 PM
Ek9_Cuhzz
Sep 22, 2010 06:30 PM
DIRTYsouthBB6
Nov 17, 2005 08:51 PM
