d16z6 crank/block girddle question?
Old Mar 17, 2004 | 03:53 PM
D-booster's Avatar
Default d16z6 crank/block girddle question?
Durring the rebuild of my engine I found out that my crank and girddle is totally F%&^%$ up when the crank moved and grind up against the thrust washer along with the girddle. I found a crank/block girddle on ebay but its from a 91 si engine..I know that crank works on d16z6 blocks but not sure about the girddle, anyone with info on this? let me know thanks.
Old Mar 17, 2004 | 04:20 PM
RyanEJ8's Avatar
Default Re: d16z6 crank/block girddle question? (D-booster)
The girdle should fit, but you have to get it align honed, which can be quite pricey. You might be better off to just buy the whole block.
toolbox21
Feb 2, 2009 06:11 PM
mugenkilla899
Nov 15, 2006 11:18 AM
D-booster
Mar 20, 2004 05:49 PM
