Where is the drain bolt and filler on '94 GSR Tranny????
Old Mar 17, 2004 | 03:10 PM
Drian's Avatar
Default Where is the drain bolt and filler on '94 GSR Tranny????
I'm up under the car and cant seem to locate it? Need help fast. Daylight running and car is up on jacks! Peace!
Old Mar 17, 2004 | 03:21 PM
everidge4's Avatar
Default Re: Where is the drain bolt and filler on '94 GSR Tranny???? (Drian)
the drain bolt is on the bottom of the passenger side, if you look through the whell well you can see it it takes a 3/8 rachet (no socket) just the end of the rachet. the fill up spot, look down behind the intake tube there is a 17mm bolt take out that, if you dont have a funnel to reach there, put the tip of the oil bottle in the little hole on the top of the tranny under a rubber cap. it takes about two quarts but just fill it until it starts to run out of the hole where you took out the 17mm bolt
Old Mar 17, 2004 | 03:28 PM
cougar10ag's Avatar
both bolts are on th SIDE of the tranny. passenger side, remove the wheel and you'll see a bolt requiering a 3/8 ratchet. and the other requires a 17mm socket
if your signed up on T-I.net, click this, then hit refresh a couple times and it will show up
http://www.team-integra.net/im...l.jpg
rockcity
14
Aug 21, 2008 10:52 PM
doom26464
Jun 18, 2008 07:10 PM
jimmyrab
May 20, 2008 07:03 AM
dcrbin22
Sep 15, 2004 10:38 AM
asubennett
Aug 21, 2003 05:14 PM
