ITR piston and rings fit on GSR stock rods/bore?
all besres have a 81mm bore except for the b20 which has a 84mm bore.
and yes itr pistons fit in your car but i would much rather you get b16 pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpG2 »</TD></TR><TR><TD CLASS="quote">im curious as well..why b16?</TD></TR></TABLE>
because
usdm itr pistons in a gsr = 10.8 CR
jdm itr =11.1
b16a pr3 pistons = 11.3xx
and ctr's suck and only should be used if u want problems or if you run race gas
Modified by riceball777 at 12:49 AM 3/18/2004
because
jdm itr =11.1
Go with JDM ITR's, the R series had the skirts coated with molybdneuim (sp) which made them more slippery. Less power lost to pushing the piston, more power to the ground.
CTR's are just asking for trouble with the high CR.
stealin ur post here mike but, if i was gonna do a first gen b16 in a crx and wanted a gsr block..would it be better to use the b16 pistons in the gsr block since id already have em?
To answer the original question: yes they will fit. The JDM ITR pistons will work fine, as will the B16 PR3's or even the P30's. Assuming you get some mild tuning, you shouldn't have any issues whatsoever running on pump gas with any of these.
I would get JDM ITRs over B16As because of the teflons on the skirts. I would not go with the JDM CTRs because compression is too high for street use. BTW, the JDM ITRs yield closer to a 11.2-11.3 CR in a gsr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">I would get JDM ITRs over B16As because of the teflons on the skirts. I would not go with the JDM CTRs because compression is too high for street use. BTW, the JDM ITRs yield closer to a 11.2-11.3 CR in a gsr.</TD></TR></TABLE>
If you run a vafc you can tune it good enough to run ctr pistons. Those would be my choice. Well, my choice would be 9:1 wiseco pistons and boost but.... for factory pistons then ctr all the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import-tooner »</TD></TR><TR><TD CLASS="quote">
If you run a vafc you can tune it good enough to run ctr pistons. Those would be my choice. Well, my choice would be 9:1 wiseco pistons and boost but.... for factory pistons then ctr all the way. </TD></TR></TABLE>
Funny because Im going to be running hondata(which is superior to a vafc) and Im not going to run CTRs in my car...ofcourse I dont do things that are "good enough" to my car either.
