l/s throttle body size
i may be buyin a l/s throttle body becuase my tps went out, wonderin if the tb is the same 60mm as the rest of the b-series, checked out the sohc upgrade post but all it said was
"VTEC B series and B20 (CRV) throttle bodies are all 60mm in size. Except for the ITR, which is 62mm. The H22 is also a 60mm throttle body, while the Civic gets a puny 56mm."
nottin about the l/s.
nebody know? i assume its also 60mm but just wondering.
