SiR resistor box with DX...
Old Mar 17, 2004 | 08:47 AM
doublethink's Avatar
Default SiR resistor box with DX...
I have a crx dx, doing a b16a1 swap, amazingly hmotors sent me an engine with the resistor box for the injectors, can i use it with the DX harness?
sorry if this questions been asked before, i did look.
Old Mar 17, 2004 | 08:55 AM
Origin's Avatar
Default Re: SiR resistor box with DX... (doublethink)
did you convert to mpfi? you will use your stock engine harness which should be converted to mpfi.
Old Mar 17, 2004 | 08:58 AM
ITR981002's Avatar
You'll have to modify your DX harness. It will not simply plug in. Look for MPFI swap info in the Faq section of this forum. You'll find plenty of info. If you can't figure it out from there, you may want to have a friend help you. Wiring a DX for a B16 can be a challenge if you've never done anything like that before.
Cole89ef
Feb 9, 2009 06:35 AM
Red_ED8
Sep 5, 2007 04:40 AM
P h i l
Feb 1, 2005 02:52 PM
doublethink
Mar 20, 2004 06:08 PM
HybriDNA
Feb 9, 2003 05:07 PM
