some thoughts on oil and tranny oil...
Old Mar 17, 2004 | 07:08 AM
SOHCMAN's Avatar
Default some thoughts on oil and tranny oil...
Everyone here seems to think(well most everyone) that GM syncromesh is the best, so I head over to the local dealer and they 1.dont stock it and 2.charge 15 bucks a quart??? I thought it was like 11 or 12, but 15?
They did have the regular stuff that isnt friction modified, so I left and went to autozone. They had PENZOIL syncromesh in a yellow tube that looked like it should have gear oil in it. Wasnt sure abou it so I didnt get it.
Then I remember reading about how mobil one synthetic is friction modified... Is there a reason that mobil one would not be a good choice to use in the tranny? The new MTF from honda for 94-and on is suposedly "part synthetic" and with people having such god luck with the full synthetic syncromesh, I just wonder why I havent heard of people using this or any other friction modified synthetic motor oil
heck, what about amsoil?
I am having trouble deciding what to get should I just use the honda and deal with rough syncros?
thanks sohc
Old Mar 17, 2004 | 07:15 AM
v4lu3s's Avatar
RTFM
i used to use mobil1 10w30 in my tranny
hen switchedto penzoil syncromesh....i like it a LOT.
smoother and quieter.
Old Mar 17, 2004 | 07:16 AM
KGAccord's Avatar
Default Re: some thoughts on oil and tranny oil... (SOHCMAN)
imo, if the honda stuff works for you use it. only if your synchros start giving you problems would i switch.
Old Mar 18, 2004 | 02:47 PM
SOHCMAN's Avatar
Default Re: some thoughts on oil and tranny oil... (KGAccord)
well, they are, which is why I am wondering if mobil one will smooth things out like the Gm stuff will...
Old Mar 18, 2004 | 06:08 PM
shrekz's Avatar
use redline oil. it will cure your synchros right up
Old Mar 18, 2004 | 08:08 PM
nuc79's Avatar
Default Re: some thoughts on oil and tranny oil... (shrekz)
the pennzoil synchromesh (even though it's in a gear-oil looking container), is the same stuff that's in the GM bottle at the dealership. In fact, I think the Pennzoil bottle even references the GM part # on the bottle. You would know as soon as you opened it if it was gear oil. It would be thick as molassas and smell like ***...
And unless you have an LSD in your tranny(with clutch disks), i've read of great results with the regular(non-friction mod) Synchromesh.
I'd have to say it's safe to save 60% and buy it at Autozone. Not only safe, but smart too....
Old Mar 18, 2004 | 09:09 PM
iam7head's Avatar
Default Re: some thoughts on oil and tranny oil... (nuc79)
GM is worth it, at least cheaper than replacing all the syncro
"double clutch is your best friend"
Old Mar 19, 2004 | 06:08 AM
SOHCMAN's Avatar
Default Re: some thoughts on oil and tranny oil... (iam7head)
Will Mobil one syn be bad then? because I just put it in last night... :D Thanks for all the replies...
sohc
Old Mar 19, 2004 | 11:23 AM
nuc79's Avatar
as long as it's 10W30, it's in spec for what Honda recommends. all a matter of personal preference
mattbatson
Apr 8, 2012 04:28 PM
83rolla
Dec 28, 2011 07:46 PM
DiMpL3s
54
Nov 29, 2007 07:52 AM
meagainsttheworld
40
Sep 5, 2006 02:52 PM
Aespooncivic
29
Apr 1, 2005 12:14 PM
