How much would a complete motor swap cost
Old Mar 17, 2004 | 05:05 AM
Layziebtnh055's Avatar
Default How much would a complete motor swap cost
including the motor ecu and 5 speed tranny and labor
Old Mar 17, 2004 | 05:12 AM
qwksi1's Avatar
Default Re: How much would a complete motor swap cost (Layziebtnh055)
WOW!
Old Mar 17, 2004 | 05:14 AM
I Gotta Question's Avatar
ummm not to flame, but what engine are you wanting to swap??? And labor varies by who you go to just check out these sites. http://www.totaljdm.com http://www.hasport.com
Old Mar 17, 2004 | 05:18 AM
GreenMachineRex's Avatar
b16. around 4400.
Old Mar 17, 2004 | 05:44 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Layziebtnh055 &raquo;</TD></TR><TR><TD CLASS="quote">including the motor ecu and 5 speed tranny and labor</TD></TR></TABLE>
Depends on the engine you want and the car you're swapping it into.
Some engines cost more than others; some engines require more parts to install than others; some cars require more parts for an engine swap than others.
Labor could cost just about anything depending where you go; figure at least $65/hour.
Search.
Old Mar 17, 2004 | 06:06 AM
jsteezy1290's Avatar
Default Re: How much would a complete motor swap cost (Targa250R)
i recomend getting the swap from altered imports in washington i bought my b16a for 1100 included shiftlinkage too. any performance shop in your local town should atleast now where the swap could be done
Old Mar 17, 2004 | 10:23 AM
crxtreme89h's Avatar
Default Re: How much would a complete motor swap cost (jsteezy1290)
Check here
https://honda-tech.com/zerothread?id=802298
Old Mar 18, 2004 | 09:55 AM
cjwerks's Avatar
I have a complete d16a6 w/ecu,supercharger, and tranz. if you're interested you can contact me at Clay@kustomkaraudio.com
Old Mar 18, 2004 | 10:02 AM
XEF-9X's Avatar
Default Re: (GreenMachineRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex &raquo;</TD></TR><TR><TD CLASS="quote">b16. around 4400.</TD></TR></TABLE>
holy ****. you mid US kids GET RIPPED THE **** OFF
I can do a b16 installed for 2200. labor parts everything!!! DAMN I LOVE CALIFORNIA
Old Mar 18, 2004 | 12:07 PM
Default Re: (XEF-9X)
I'll do it for you for $2199.
Old Mar 18, 2004 | 12:23 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XEF-9X &raquo;</TD></TR><TR><TD CLASS="quote">
holy ****. you mid US kids GET RIPPED THE **** OFF</TD></TR></TABLE>
He had to have been talking about a 2nd-gen JDM B16A with LSD . . . or a B18C or something. I don't think anyone is stupid enough to pay $4400 to have a 1st-gen JDM B16A installed.
Old Mar 18, 2004 | 12:35 PM
Kidnkorner's Avatar
if you were in the phoenix area it would be 3200-3800 installed for a 1st gen swap into a 4th gen civic/crx depending mostly on what had to be replaced.
but definately replace
plugs
wires
waterpump
timing belt
top end gaskets
and if you really can afford it a new distributor ( i have a OBD0 if interested new!)
Old Mar 18, 2004 | 01:39 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: How much would a complete motor swap cost (Huggy Bear)
$2200? yea, in parts.
$1250- motor/tranny/ecu ($300) option for LSD
$300_$400-water pump/timing belt/head gasket/cam seals/VC gasket
$350-HaSport mounts
$100-modify axles
$60-wiring harness
$70-throttle cable
$40-coolant/oil/filter
^^^^minimal needs (if you want it done rite)
good things to change rite away
$360-clutch
$300-flywheel
$300_$400-header (depending on brand)
$100_$250-intake ( " " )
IMHO, if your gonna do it, do it rite
Old Mar 18, 2004 | 03:05 PM
newBcrxer's Avatar
Default Re: How much would a complete motor swap cost (LudeEFv2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeEFv2.0 &raquo;</TD></TR><TR><TD CLASS="quote">$2200? yea, in parts.
$350-HaSport mounts
$100-modify axles
$60-wiring harness
$70-throttle cable
^^^^minimal needs (if you want it done rite) </TD></TR></TABLE>
are those stuff needed for a b16? if i wanna swap a b18c1 into my crx .. are those the stuff i need too?
Old Mar 18, 2004 | 03:13 PM
XEF-9X's Avatar
$350-HaSport mounts
$100-modify axles
$60-wiring harness
$70-throttle cable
$360-clutch
$300-flywheel
IMHO, if your gonna do it, do it rite </TD></TR></TABLE>
2200 is an easy price to get it for.
who says water pump , timing belt and head gaskets costs 400 bucks?
you must be nuts! the shop by my house gets all the parts for you.
custom mounts,linkage. they get shop prices from honda on parts.
they replaced my water pump, and timing belt including labor for 250.00.
the shop charges 2200 for a straight b16 swap.
if you want anything extra I.E. water pump/ timing belt you request it
and they only ask you pay for parts. they will put anything you want in for free at the time of the swap (cams, pistons etc.) a b16 swap with new clutch, timing belt, head gasket and water pump ones between 2350-2400. not bad I say.
Old Mar 19, 2004 | 01:50 AM
LudeEFv2.4's Avatar
Default Re: How much would a complete motor swap cost (XEF-9X)
ok look, you and me know people and can get parts for price.
someone who is just walking into a shop looking for a swap and dosen't have connections is not gonna get quoted the same prices. it's called mark-up, thats how you pay the rent if you are a shop owner. not by hooking people up.
I was just trying to give him a realistic guide for what to expect. and no, I'm not nutz since you asked.
:EDIT:<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeEFv2.0 &raquo;</TD></TR><TR><TD CLASS="quote">$300_$400-water pump/timing belt/head gasket/cam seals/VC gasket
sorry, i meant to put cap and rotor in there as well. but if you can do all that with labor using all new Honda genuine parts at $250, then more power to ya
Modified by LudeEFv2.0 at 11:02 AM 3/19/2004
Old Mar 19, 2004 | 03:49 AM
T S R Performance's Avatar
Usually if you have everything and we dont have to order anything, it'll run you from 600-700.
wildstallion
Nov 3, 2004 12:24 PM
MounDoggy
Apr 21, 2004 04:51 PM
Suzukablue
22
Jul 5, 2003 03:47 PM
lobo
Feb 11, 2003 12:42 AM
