Wiring problem swaping a d16y8 in my 92 vx
I'm having problems with the wiring in my 92 civic vx. does anyone have a wiring diagram of which wires are which? I'm gonna use the p2p ecu... but all the wires on the drives side, the connections don't match up so I need to know which wires go with which wires... also I'm using the harness that came with the engine, and the cabin harness that came with the car... so ya I NEED HELP! thanks
from my experience, i would prefer to use the factory wiring harness from the car along with the original engine. all of your sensor should be primarly the same with the exception of the altenator and fuel injectors and maybe the distributor. anyway go to http://www.hondata.com, or try http://www.locashracing.com for adapters, go buy a helms manual or a haynes manual all the schematics you will need you can find in those.
what about the wiring into the p2p ecu.. cus my connections are different... so what would I have to do to use the new ecu?
ok.. I'm goin obd1, can anyone tell me what that sensor is between the injectors? and how to wire that into the obd1 harness?... also, now that I've decided to go obd1, does anyone know where I can get a cheap p28?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killersohc »</TD></TR><TR><TD CLASS="quote">ok.. I'm goin obd1, can anyone tell me what that sensor is between the injectors? and how to wire that into the obd1 harness?... also, now that I've decided to go obd1, does anyone know where I can get a cheap p28?</TD></TR></TABLE>
dont be afraid of the sensors bro. it will be cheaper to by the adapter harness from locash racing.
the adapter is made to plug into your fatory harness and plug into what ever ecu you specify (he makes them by order on the spot and does all the repining necessary to make every thing work with your ecu. check it out.
or you can buy a p 28, which is a very good ecu.
adamisgreat88
Aug 24, 2009 01:52 PM
EGcivicBoy
Feb 2, 2004 01:10 AM
bobbysteelz
Jul 8, 2003 01:12 PM
