installing rear passenger side fender on EG 4dr
Old Mar 16, 2004 | 09:04 PM
dunkd's Avatar
Default installing rear passenger side window on EG 4dr
i broke my window trying to break into my car bc i didnt have keys anyway i have the new windown and took the old one out, all the glass, unscrewed the two 10mm's... now the problem is getting the new
window in... i cant get it to fit in there... is it sposed to just slip down in there no problems?
Modified by dunkd at 10:48 AM 3/17/2004
Old Mar 17, 2004 | 05:42 AM
japspecjohn's Avatar
Default Re: installing rear passenger side fender on EG 4dr (dunkd)
change the subject you must of been shot when you wrote this
Old Mar 17, 2004 | 09:48 AM
dunkd's Avatar
hahaha wow, WINDOW
Old Mar 17, 2004 | 09:53 AM
MAD SOHC's Avatar
You're gonna need a saw and a welder!
Old Mar 17, 2004 | 09:55 AM
Ricey McRicerton's Avatar
Default Re: installing rear passenger side fender on EG 4dr (MAD SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD SOHC &raquo;</TD></TR><TR><TD CLASS="quote">You're gonna need a saw and a welder!</TD></TR></TABLE>
I'm guessing you didn't read the post at all..just the title. To help you out, I'll check my helms when I get home man. I'm in class and don't have it.
PM me to remind me or I won't do it!
Old Mar 17, 2004 | 03:27 PM
amy's Avatar
amy
Default Re: installing rear passenger side window on EG 4dr (dunkd)
lol i knew when i first read this last night it wasn't right......
Old Mar 17, 2004 | 03:54 PM
Built Beast's Avatar
Default Re: installing rear passenger side fender on EG 4dr (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'm in class and don't have it.
PM me to remind me or I won't do it!</TD></TR></TABLE>
now that is dedication to HT or the lack of care for school
Old Mar 17, 2004 | 04:11 PM
Default Re: installing rear passenger side fender on EG 4dr (R33CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R33CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">
now that is dedication to HT or the lack of care for school </TD></TR></TABLE>
Haha, all beginner's classes at college are killing me. Plus sitting in a class with a great internet connection and access to HT all day doesn't help any!
Oh well, here's how you do it (THIS IF FOR AN EK, but should be the same thing pretty much)(this is copied from the Helms manual damn near word for word):
<U>Removal:</U>
First, remove all of the interior back there (including the: rear seta back and rear seat cushion, rear center shelf and rear side shelf, rear trim panel and side trim panel, upper anchor bolts from the front and rear seatbelts and the quarter trim panel).
From inside the car, use a knife to cut through the quarter glass adhesive all the way around.
<U>Installation:</U>
Using a knife, scrape the old adhesive smooth to a thickness of about 2mm on the bonding surface around the entire quarter glass opening flange. (don't scrape down to the painted surface. Remove all rubber dams from the body, if any of the clips are broken)
Clean the bonding surface with a sponge dampened in alcohol.
If the quarter glass is to be reinstalled, scrape off all old adhesive (disreguard this in your case, but I'm going to put this in the FAQ thread, so I figured I'd add it all).
Clean the glass very well with the alcohol sponge.
Glue the upper and lower dams to the inside face of the quarter glass, as shown, to contian the adhesive during installation. (there are small application mark locations on the class, that look like little Vs. Start the dams there and they should end at the other end of the glass at the other V. The dams go across the top and bottom of the glass).
Install the quarter glass trim on the quarter glass, the glue the upper and lower clips. (these clips go around the edge of the glass twoards the front of the car).
If the old quarter glass is to be reinstalled, apply butyl tape to the quarter glass, and seal the body hole with a peice of urethane tape. (this goes in the edge twoards the back of the car where the window is the smallest).
With a sponge apply a light coat of glass primer to the inside face of the quarter glass, and wipe it off with gauze or cheesecloth.
With a sponge, apply a light coat of body primer to the original adhesive remaining around the quarter glass opening flange. Let the primer dry at least 10 minutes.
Thorougly mix the adhesive and hardener together on a glass or metal plate with a putty knife.
Fill a cartridge with the adhesive/hardner mixture and then install the cartridge into a caulking gun. Try to apply it without any air pockets. Run a bead around the glass 22.5mm from the edge of the glass.
Use suction cups to hold the quarter glass over the opening, align the clips and set it down on the adhesive. Lightly push the quarter glass until it's edges are fully seated on the adhesive all the way around.
Scrape or wipe the excess adhesive off with a putty knife or towel.
Let the adhesive dry for at least one hour, then spray water over the quarter glass to check for leaks, then fill any leaks with sealant.
Reinstall all removed interior peices.
Good luck man, looks like a helluva involved process.
Old Mar 17, 2004 | 06:00 PM
dunkd's Avatar
wow that seems pretty in depth... i just took another stab at it a little while ago and was able to get her down in there... just took a little extra elbow grease... thanks for the help tho!
Old Mar 17, 2004 | 06:02 PM
amy's Avatar
amy
Default Re: (dunkd)
hope you did it right and your window doesn't fall out!
Old Mar 17, 2004 | 06:06 PM
=GAME='s Avatar
hey ricey thats some good info for a COUPE
...but if i read right it said 4 door
...maybe its similar to the front glass. well since you remove all the panels and stuff since you're stuck on the 2 10mm bolts, remove all the window trimming and weather strip so you will have a bigger gap to work with. then with the new glass i believe you will have to slide it in from the outside tilted on an angle with the right bottom going in first. then just try to maneuver it around and see if it fits.
Old Mar 17, 2004 | 06:53 PM
dunkd's Avatar
i didnt remove the weather stripping. just jammed it down in there. works fine.
Old Mar 17, 2004 | 06:55 PM
Default Re: installing rear passenger side fender on EG 4dr (=GAMEOVA=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVA= &raquo;</TD></TR><TR><TD CLASS="quote">hey ricey thats some good info for a COUPE
'DOH!!
Oh well dammit..still linked for the coupe crew!
Old Mar 17, 2004 | 07:07 PM
WalkingKenshin
Guest
Posts: n/a
duhhh do
JadeInnBoyZ
May 3, 2008 09:33 AM
707the89fu
Northern California (Sales)
12
Apr 3, 2008 08:46 AM
mustang5.slow
Apr 3, 2007 05:10 PM
sonicSVT
Apr 27, 2003 05:50 PM
