Stripped tuner style lug nut, please help!
Old Mar 16, 2004 | 08:35 PM
brx017's Avatar
Default Stripped tuner style lug nut, please help!
Tonight I almost finish taking out the engine from my 93 Si, when I realize I cant get 2 lug nuts off. I already have everything disconnected, and even have my axle nuts off, when I notice the idiot that worked on my car a few months back didnt have a key for my lug nuts. Instead of asking me or looking for one, he must have beat something in them to get them off. Now 2 of them are stripped, and I cant get the wheel off. Its midnight so Im quitting for tonite, but what are my options? Take everything apart and knock the studs out from behind? Ive already tried cutting a groove and using a prybar / crowbar / hammer / long pipe / dremel / vise grips / screwdriver / anything else i could find. I have two extra "keys", I wonder if i JB welded them in, if it would harden enough to work? That would be easier I would think, but yall think it would be worth the trouble trying? Someone please help me, I cant wait to get in my JDM B18C-R.
Thanks in advance...
Old Mar 16, 2004 | 08:36 PM
b16ahybrid's Avatar
Default Re: Stripped tuner style lug nut, please help! (brx017)
Drill them.
Old Mar 16, 2004 | 08:38 PM
brx017's Avatar
from behind or the front? That would take forever wouldnt it?
Old Mar 16, 2004 | 09:06 PM
fishnfst's Avatar
Do just like the last guy that removed your wheels did. Get a socket that fits snug on the lug and beat it on with a hammer and use a breaker bar and spin them off. Use Half Inch drive if you have it. You might break a 3/8 drive. Worse case scenario you can go to sears and they have a wheel lock removal tool that is basically a socket that is grooved so it tightens itself onto the lugnut the more you turn it.
Old Mar 17, 2004 | 07:17 AM
brx017's Avatar
Thanks, but does anybody think the JB Weld idea would work?
Old Mar 17, 2004 | 07:21 AM
xerox445's Avatar
Default Re: (brx017)
jb weld is weak as hell
Old Mar 17, 2004 | 04:04 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brx017 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, but does anybody think the JB Weld idea would work?</TD></TR></TABLE>
NO. It's not strong enough to withstand the torque required to remove the lug nut
Old Mar 17, 2004 | 05:13 PM
ImportMotorSpec's Avatar
If you are carefull, heat the lug up with a torch and thenBang a socket onto them and try to remove them. Will usually work. If that doesn't work drill or remove the steering knuckle and take the whole thing to a shop...
Old Mar 18, 2004 | 12:52 PM
brx017's Avatar
Thanks for the advice. I talked to a guy at work today in maintenance. Im gonna take the whole thing apart and bring it in. He's gonna weld some nuts to the lugs for me.
THEUSED
Aug 31, 2009 02:58 PM
liem43
Nov 11, 2005 07:25 PM
shooitzlinh
Mar 20, 2005 06:44 PM
sjteg
Jul 13, 2003 06:39 PM
burn
Jul 23, 2001 08:22 PM
