When shifting, hearing a little click noise from Shifter.
Heh, I know what you're talking about. I've noticed this on my shifter as well - do you have the stock one?
Eitherway, the problem lies in the actual shifter bolt... It's hard to explain but I'll try my best. When you remove the shifter itself, you'll notice that there is a bolt holding the shift rod at the bottom of the shifter, the 'click' that you hear is whenever this bolt is too loose. You can tighten it a bit and it will go away, a permanent fix would be to add a new short shifter (maybe) or come up with some sort of spacer idea to keep the little bushing/spacer thing from moving around. Locktite on the threads might work too.
I probably made this more confusing than it really is! Sorry.
I understand you dude. Mine is loose as all get out. I bought that short shifter from Evasive Motorsports and the hole at the bottom of the shifter was huge. I didn't have anything to fill it with, so I used a "metal tube" that came with my new shifter bushings from NEUSPEED. It's still loose but oh well. Won't hurt anything I guess.
slash00R
Nov 1, 2004 07:23 PM
whizdumb
10
Mar 18, 2003 03:55 PM
