Spoon p13 vs. stock p13?
i know that chipping really aint that great but i was wondering if anybody has tried using the spoon ecu that jdm **** sells. this is basically for a temporary setup because i am sick of being obd2, nearly stock and, i need some extra power till i get my motor built. once again im not talking about the cheap ebay ones im talkin bout the real thangs. thanks guys!
To get it chipped don't you have to send the computer to them...?
Because that would suck. I've been thinking bout getting mine chipped too, but I can't afford not driving...
lucky you guys, may be I'll make a road trip to get the spoon program, lol.
I don't know of any shop that does it near me, but then again I haven't really asked that much about it.
Would it perform good with a VAFC?
Yes, chipped ecu's are crap. The NA ones give you a bit more advanced timing and a tiny bit of fueling with an increased rev limit.... which for the H series is useless on a stock motor. A 3whp gain across the board is blah. I thought I have seen someone in the past get a 7whp increase with a v-afc on a stock motor?
A better solution is to run your stock ecu with a v-afc. It will give you the option of setting your own fuel curves unique to your motor as well as your vtec engagement point. As far as timing is involved, you can do that via the distributor but in my opinion... I would leave it alone. Advanced timing leads to detonation and if you do not know what you are doing you can easily destroy your motor.
what<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">lol sick of being obd2....it's really not that big of a deal</TD></TR></TABLE>
well for some reason my car is really slow, and whenever i shift i get a black cloud out back, my friends say it even happens when im not on it. we think im just running rich and that if i swap ecus that the problem should go away, i would probably also be adding a testpipe...
