WHAT KIND OF EXHAUST 3" or 2.5"????
Old Mar 16, 2004 | 08:03 PM
94`Gsr_Hatch's Avatar
Default WHAT KIND OF EXHAUST 3" or 2.5"????
im getting a b18b motor built with turbo...ill be running 6-8lbs of boost...im thinking of getting a 2.5in gt spec for my eg hatch...does apex make 3in? what should i do in terms of power 2.5 or 3in? who makes 3" for civics if apex doesnt? i know thermal does but that oval **** is ugly as hell...some1 let me know soon...ill have to decide in a few days when my motor gets out of the machine shop
Old Mar 16, 2004 | 08:09 PM
Icey112's Avatar
Default Re: WHAT KIND OF EXHAUST 3" or 2.5"???? (94`Gsr_Hatch)
3 inch
Old Mar 16, 2004 | 08:17 PM
jdmjason's Avatar
Default Re: WHAT KIND OF EXHAUST 3" or 2.5"???? (Icey112)
3 inch will give you the most power, but i don't know.....wont the piping be too big and kinda hang low....and the 3" apexi N1 looks big as hell on civics.
Old Mar 16, 2004 | 08:21 PM
clm's Avatar
clm
Default Re: WHAT KIND OF EXHAUST 3" or 2.5"???? (jdmjason)
With 6-8 pounds of boost, 2.5" piping should be fine. Maybe throw on a cut-out for track days.
Old Mar 16, 2004 | 08:22 PM
at what psi should i get a 3" if 2.5 would be sufficient for the boost im running right now
Old Mar 16, 2004 | 08:27 PM
clm's Avatar
clm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94`Gsr_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">at what psi should i get a 3" if 2.5 would be sufficient for the boost im running right now</TD></TR></TABLE>
Normally it goes by expected power output. Search through the FI forum for the recommendations.
Old Mar 16, 2004 | 08:36 PM
Dengar's Avatar
Default Re: WHAT KIND OF EXHAUST 3" or 2.5"???? (clm)
Another think you need to look at is what manifold you are going to be running. Some manifolds (drag) are notorious for not holding boost very well, and running a 3 inch exhaust will only make spiking a more common occurrence. People make a lot of really good power in the low psi levels with 60mm exhaust. I would stick with that.
Old Mar 16, 2004 | 08:37 PM
J.R.'s Avatar
Default Re: WHAT KIND OF EXHAUST 3" or 2.5"???? (Dengar)
3 inch from kteller
Old Mar 16, 2004 | 08:54 PM
TrboInteg's Avatar
Go with a 3 inch exhaust and downpipe if you want to eventually turn the bost up.
ketchup!
Jul 21, 2008 08:46 AM
I got a honda
Jul 30, 2005 04:26 PM
1SlowSi
Nov 9, 2004 05:32 AM
Blazeone
Jun 12, 2003 03:17 PM
(__________)
Aug 18, 2002 09:50 PM
