mystery trans/motor?
Old Mar 16, 2004 | 06:29 PM
stealthhatch's Avatar
Default mystery trans/motor?
i got a swap done on my civic sedan. the motor is a b16a but has unusual parts like the only water pump that fits it is from a usdm b17 from a 93 gsr.but i know the motor is a 95 i was also told the trany was a gsr, but the only axles that fit are also from a 93 integra. and when i had a shop fix my cincros they said they couldn't get the right bearing package they had to mix and match them. any answers would be great thanks
Old Mar 16, 2004 | 06:30 PM
Smith Wise's Avatar
Default Re: mystery trans/motor? (4door)
engine code?
tranny code?
what ecu are you using? ecu code?
Old Mar 16, 2004 | 06:31 PM
Default Re: mystery trans/motor? (Jswpstdoff)
i know ts a 95 gsr ecu
Old Mar 16, 2004 | 06:32 PM
and the motor says b16a
Old Mar 16, 2004 | 06:34 PM
Smith Wise's Avatar
what parts did they mix and match to fix the bearing?
Old Mar 16, 2004 | 06:36 PM
they couldn't get the right parts packages for the tranny they had to mix and match parts from different sets
Old Mar 16, 2004 | 06:38 PM
Smith Wise's Avatar
that's weird...
i don't have a clue what to tell you unless i can physically see the engine, but even then i don't know what help i would be....
BUMP
Old Mar 16, 2004 | 06:47 PM
Discosteak's Avatar
take a pic of the whole motor
OUTKAST1779
Transmission & Drivetrain
Mar 19, 2011 11:15 PM
b16edeg
Oct 9, 2007 04:17 PM
phat87mazdarx7
Dec 27, 2006 12:13 PM
B3AS
Mar 26, 2004 01:12 PM
Kool305
Apr 25, 2002 10:31 AM
