DC2 seats in EK
I have searched and came up with nothing. I was wondering if my DC2 seats will bolt right in to a EK? I am selling my seats and had some questions from potential buyers. THanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunkn_tyger »</TD></TR><TR><TD CLASS="quote">nothing needs to be changed....
my itrs were a straight bolt on for my EK</TD></TR></TABLE>
i have the itr rear seats in my hatch and i had to change the back rails, but the bottom cushion will fits but there will be a gap on each side. But i think if you have a coupe is should fit without anytype of customizing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hair_rice »</TD></TR><TR><TD CLASS="quote">so you are sayin that gsr rear seats will fit a EJ with no mods? im just wonderin cuz i wanna do that if its possible</TD></TR></TABLE>
you have to swap the outer rail and inside assembly from the EJ to fit.
depends on year of EJ.....92-95 bolt in, 96-00 must modify rails or floor board.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonas99 »</TD></TR><TR><TD CLASS="quote">
you have to swap the outer rail and inside assembly from the EJ to fit.</TD></TR></TABLE>
not to sound dumb but what do you mean by inner assembly?
if you pull your seat you'll know what they mean... it's the seatbelt buckle assembly and stuff... just a few bolts... real easy... just did del sol seats in to my "ek" ('99 ej coupe) last week
not to sound dumb but what do you mean by inner assembly?</TD></TR></TABLE>
The whole rail/bracek that attaches to the inside of the seat (twoards the center of the car)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mMmdoOonut »</TD></TR><TR><TD CLASS="quote">if you pull your seat you'll know what they mean... it's the seatbelt buckle assembly and stuff... just a few bolts... real easy... just did del sol seats in to my "ek" ('99 ej coupe) last week</TD></TR></TABLE>
ur talkin about the front right? i need to find what they meant for the back. thanks though
the back won't fit right in the 96-00 coupes. the teg rear bench is narrower on the bottom seat cushion so there'll be a gap on either side. the upper backseat in the teg folds 50/50 so you have to do some fabricating to get it to fit right with the 60/40 configuration on the civic. i have gsr fronts but kept my backseats stock - just wasn't worth the work. hatchbacks will have less fitment problems as they're 50/50 split but it will still take some work and there will still be a gap. this is all assuming you're using the 2dr teg seats - the 4 door bottom seat cushion is wider. hope that helps.
anyone have teg backseats in a 96-00 coupe?
ej8hybrid
May 17, 2012 09:27 PM
