Question for anybody using a GSR Throttle Body
Old Mar 16, 2004 | 12:46 PM
D-Man's Avatar
Default Question for anybody using a GSR Throttle Body
I'm going to use either a Venom or Golden Eagle intake and niether has a throttle cable mount.I'm going to try and use a GSR TB that has a cable mount right on it.If your running this TB in your EF,what throttle cable did you use? and does the cable rub up against the hood?
This is a pic of the GSR TB I'm thinking about buying,sorry its upside down
Modified by D-Man at 5:05 PM 3/16/2004
Old Mar 16, 2004 | 01:32 PM
silverCRXTC's Avatar
Default Re: Question for anybody using a GSR Throttle Body (D-Man)
I would imagine that you would have to use a gsr throttle cable to acccommodate
that bracket.
Old Mar 16, 2004 | 01:50 PM
D-Man's Avatar
Default Re: Question for anybody using a GSR Throttle Body (silverCRXTC)
does the GSR Cable fit in a EF?
Old Mar 16, 2004 | 01:56 PM
Rywire's Avatar
I dont see why it wouldnt. Ryan
Old Mar 16, 2004 | 02:00 PM
D-Man's Avatar
Default Re: Question for anybody using a GSR Throttle Body (droppedcrxsi)
I figure were its mounted to the firewall and gas pedal I might run into problems
Old Mar 16, 2004 | 06:31 PM
D-Man's Avatar
ttt
Old Mar 16, 2004 | 07:32 PM
bspeed's Avatar
I out a gsr t/b on my engine, I removed the throttle wheel and replaced it with one from an EX throttle body. WARNING this is a pain in the *** but and I recommend doing this in an area where you will not lose anything, eg. not in the engine bay. When changing the wheel, use the sohc return spring not the gsr as the wheels are clocked just a bit different.
Old Mar 16, 2004 | 08:35 PM
Fobtions's Avatar
Default Re: Question for anybody using a GSR Throttle Body (bspeed)
Old Mar 16, 2004 | 08:36 PM
Fobtions's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bspeed &raquo;</TD></TR><TR><TD CLASS="quote">I out a gsr t/b on my engine, I removed the throttle wheel and replaced it with one from an EX throttle body. WARNING this is a pain in the *** but and I recommend doing this in an area where you will not lose anything, eg. not in the engine bay. When changing the wheel, use the sohc return spring not the gsr as the wheels are clocked just a bit different.</TD></TR></TABLE>
did u not read his question, the whole reason he needs to know this is cause hes in the market for a aftermarket intake manifold which doesnt support the throttle cable on one of the runners like a factory style manifold would.
i usually use a 90-91 integra cable, or u can custom the cable to work by cutting a lil of the jacketing off at the pedal side of the cable for more length.
Old Mar 17, 2004 | 04:57 AM
D-Man's Avatar
Default Re: Question for anybody using a GSR Throttle Body (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">
i usually use a 90-91 integra cable, or u can custom the cable to work by cutting a lil of the jacketing off at the pedal side of the cable for more length.</TD></TR></TABLE>
Thanks so the integra cable bolts right in without any mods,just want to be sure before I go out and buy one.
Old Mar 17, 2004 | 10:18 AM
Rywire's Avatar
Well, since you know that the teg 94-00 will fit at the throttle body end, take off your crx one, and bring it to the parts shop. If the pedal side is the same, go with the whole 94-00 teg piece. My 2 cents. Ryan
Old Mar 17, 2004 | 10:28 AM
89 CRX SI's Avatar
looks liek the bracket would hit the hood cause the GSR manifold is so so so very much lower then a aftermarket one for a ef...
Tory
Old Mar 17, 2004 | 10:39 AM
warchild69's Avatar
Default Re: Question for anybody using a GSR Throttle Body (89 CRX SI)
i use a zip tie to hold down my cluch cable.... my timing belt would rub on my cable if i used the bracket...... so i rerouted it a bit and zip tied it..... hey zip ties, bubble gum and duct tape cant be beat..
Old Mar 22, 2004 | 05:30 AM
D-Man's Avatar
Default Re: Question for anybody using a GSR Throttle Body (warchild69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warchild69 &raquo;</TD></TR><TR><TD CLASS="quote"> hey zip ties, bubble gum and duct tape cant be beat.. </TD></TR></TABLE>
Yeah,cant be beat If I wanted to ghetto it
so....anyone else use one?
92EG8
Jul 4, 2009 10:22 AM
I CRX I
Dec 17, 2006 09:06 PM
crxowner
May 18, 2006 07:39 AM
hondaitegra
Apr 20, 2003 01:20 PM
