Wiring help ??
Old Mar 16, 2004 | 10:34 AM
wtfang's Avatar
Default Wiring help ??
Can someone please point me in the right direction on where to find this wire diagram.
My cuzzin needs to wire up his distributor to the main wiring harness (Sohc 2000 EX) which has been spliced up to work with GSR ecu obd2
he has a LS-vtec setup with all kinda mayhem...
B16A first gen Head
LS bottom
well im not to sure on hondas but if you guys can help i would appreciate it
Old Mar 16, 2004 | 01:44 PM
badCRX's Avatar
New User
Default Re: Wiring help ?? (wtfang)
so you are using the SOHC distributor on the DOHC head? I would recommend getting the OBD-2 B series distributor and it will plug and play and you won't have timing issues to have to deal with.
Old Mar 16, 2004 | 02:29 PM
thad
Guest
Posts: n/a
i'm assuming you mean the connectors were cut off and spliced on the haness side and you want a diagram with the colors and positions of the wires. best bet would be to find another civic or teg OBD1 and compare the two get some spare connectors with the pins and a couple of inches of wire and start soldering
OhMy-EK9
Apr 24, 2012 09:56 PM
Spoon Si
Nov 30, 2008 05:28 PM
jsprelude
Apr 8, 2006 02:13 PM
