Somewhat Odd Seat Question
Old Mar 16, 2004 | 08:56 AM
DelSolSi93's Avatar
Default Somewhat Odd Seat Question
Hey all I did a search and found lots of info on swapping del sol seats into other civics, etc but my question is what seats will swap back into a del sol from other civics? Does it have to be 92-95 civic seats or can I use 96-00 seats? Anyone have any idea what will work? I also think the del sol seats are smaller/shorter than like normal civic seats Im trying to figure out if I will have enough head room height to fit a different seat? Thanks for any help
Old Mar 16, 2004 | 08:58 AM
skip.two's Avatar
Default Re: Somewhat Odd Seat Question (DelSolSi93)
just use the sol rails on 92-95/96-00 seats and it will work.
Old Mar 16, 2004 | 09:00 AM
DelSolSi93's Avatar
Default Re: Somewhat Odd Seat Question (jL iLLuZiOnz 9)
Are you sure, because I thought you have to change the rails when you take sol seats into a civic, so why wouldent you have to change the rails if you're bringing in a diff seat?
Old Mar 16, 2004 | 09:12 AM
scratchy's Avatar
seats are seats make them fit but for just swapping just use the right brackets and sliders
Old Mar 16, 2004 | 09:15 AM
JimmyAtlantis's Avatar
Default Re: Somewhat Odd Seat Question (scratchy)
You have to use the rails from the vehicle you are putting the seats into. I think all of the seat bases are the same.
Old Mar 16, 2004 | 09:22 AM
Uncle Ben's Avatar
Default Re: Somewhat Odd Seat Question (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">You have to use the rails from the vehicle you are putting the seats into. I think all of the seat bases are the same.</TD></TR></TABLE>
Yes, true about the rails. I used 92 DA Teg seats in my 92 cx...3 out of 4 mounts bolted in. I was told told use the cx rails/sliders.
Not sure about the seat bases cause I just used the DA rails/sliders and fu*ked my floor all up lol
STULER
May 21, 2014 06:23 PM
catsman50
Jul 15, 2010 09:57 AM
mtownek9
Oct 14, 2007 09:48 AM
mike323
19
Sep 13, 2006 05:58 PM
brasilracing
16
Nov 11, 2002 06:32 PM
