94 honda accord idles
when i start my car the engines start to crank and i have to press the gas to make the engine running. If i let go of the gas the engine would shutdown.The car would start to vibrate roughly.When the engine is hot the car would start to crank. I check the sparkplugs and it was wet. Dont know why. I had everything changed from distributor to sparkplug, did fuel injection and everything. Your help would be appreciated.
I would check the throttle body first. Sounds like its sticking and not letting enough air. Plugs are wet because you are forcing more than enough gas in there ( i assume wet = gas right?). Just my 2 cents, hard to diag without more details. Also, please work on your grammar and puncuation. Its hard to read.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boy_honda »</TD></TR><TR><TD CLASS="quote">when i start my car the engines start to crank and i have to press the gas to make the engine running. If i let go of the gas the engine would shutdown.The car would start to vibrate roughly.When the engine is hot the car would start to crank. I check the sparkplugs and it was wet. Dont know why. I had everything changed from distributor to sparkplug, did fuel injection and everything. Your help would be appreciated.
did it just start doing this after you changed the dizzy and spark plug?
W95civicEXcoupe
25
Sep 29, 2014 05:07 AM
legendisdope
Aug 14, 2006 04:25 PM
SiMateoAko
16
Aug 17, 2005 05:35 AM
