B16 running rich and coolant keeps getting low.
Old Mar 16, 2004 | 06:40 AM
Snail EK's Avatar
Default B16 running rich and coolant keeps getting low.
Hi i'm running a B16a2 in a eg. Mod are skunk2 cams\skunk2 valvetrain I\h\e with cat. I'm running a Chipped p28 with skunk2 program.
At idle there's a grey smoke that comes out. When i drive around it's a lite smoke that comes out the exhaust. It's not a headgasket or burning oil I did a wet\dry compression test. They're good. But as i tell someone to rev the motor and i stand in the back of the exhaust water jsut comes out like a river. It's not a normal water that comes out it's like someones is pouring water out of the exhaust. I pulled my plugs and they're all black burt. Can anyone tell me how to fix this or what's going on? -thanks
Also i fill my coolant up to FUll in the catch tank..But when i check it it's at min again. 4 days ago it was at Full.. Anyone know what's wrong? please help
Old Mar 16, 2004 | 09:12 AM
Snail EK's Avatar
Default Re: B16 running rich and coolant keeps getting low. (Snail EK)
Old Mar 16, 2004 | 03:28 PM
blacksol95's Avatar
i have similar problems and i found my fan switch and termostat was bad i ordered mugen parts and am waiting paitiently. drive it hard and feel the bottom hose on the rad if the fan isnt on manually jump it from the battery to see if thats the problem
Old Mar 16, 2004 | 04:14 PM
2lua's Avatar
do a pressure test on your coolant system.
Old Mar 16, 2004 | 04:18 PM
Discosteak's Avatar
you may have a cracked block
Old Mar 16, 2004 | 10:21 PM
Snail EK's Avatar
bump
Old Mar 17, 2004 | 01:06 AM
GRAVEDIGGER's Avatar
Headgasket?
Old Mar 17, 2004 | 09:09 AM
Snail EK's Avatar
bumpbump
Old Mar 17, 2004 | 09:12 AM
B2FiNiTY's Avatar
Check your water pump.
Water coming out an exhaust is completely normal.
Old Mar 17, 2004 | 08:57 PM
Snail EK's Avatar
lunareg
18
Dec 14, 2011 02:14 PM
ImportPower13
Apr 23, 2005 12:36 PM
Snail EK
Mar 17, 2004 06:26 PM
Snail EK
Mar 16, 2004 06:39 AM
CloseCall
Dec 24, 2002 07:42 PM
