Head Gaskets and compression questions for mix and match engine
Old Mar 16, 2004 | 05:07 AM
phantom_sol's Avatar
Default Head Gaskets and compression questions for mix and match engine
I have a b18c1 bottom end with a b16a3 head that i'm building. i'm in need of a head gasket and i'm undecided on whether or not to go just oem or bit the dust and go with a spoon or mugen. I have been told that this combo of block and head would decrease cr by about .2:1 from stock. i just wanted to gain some of it back. or am i just wasting my money for things i will barely notice?
the bottom is stock rebuilt from 95 gsr, head is stock from 95 del sol vtec
thanks
Old Mar 16, 2004 | 07:14 AM
CHEETAH's Avatar
Default Re: Head Gaskets and compression questions for mix and match engine (phantom_sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom_sol &raquo;</TD></TR><TR><TD CLASS="quote">I have a b18c1 bottom end with a b16a3 head that i'm building. i'm in need of a head gasket and i'm undecided on whether or not to go just oem or bit the dust and go with a spoon or mugen. I have been told that this combo of block and head would decrease cr by about .2:1 from stock. i just wanted to gain some of it back. or am i just wasting my money for things i will barely notice?
thanks </TD></TR></TABLE>
you can actually search and you'll see that the spoon mugen is a stock gasket with one layer taken out. the single layer mugen/spoon have a separating sealing. You can use the stock oem gasket and take out middle layer and use copper spray and have great results.
greg
Old Mar 16, 2004 | 08:46 AM
arent there differences in thickness though?
either way what power loss will i see with .2 lower compression over stock gsr?
ChaseIntegra
Feb 6, 2005 10:22 AM
SuicideSlide
Aug 10, 2004 01:43 PM
JDMlyfestyle
Mar 25, 2004 01:35 PM
slamdunkcivic
May 20, 2003 07:57 AM
