Tighten Throtal Cable?
Old Mar 16, 2004 | 12:33 AM
DIYaccord's Avatar
Default Tighten Throtal Cable?
Is there a way i can tighten my throtal cable to give me more throtal response?
i'd like instand responce from depressing the pedal, and don't want any "play"
and if i can, i tried looking in my chilton manuel...dumb question, but...where is the throtal cable?
Old Mar 16, 2004 | 03:34 AM
boonacka's Avatar
Default Re: Tighten Throtal Cable? (DIYaccord)
sorry to flame you but... if you dont know where the throttle cable is then i dont think you should be messing around with it.
Old Mar 16, 2004 | 05:30 AM
Mike813's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way i can tighten my throtal cable to give me more throtal response?
and if i can, i tried looking in my chilton manuel...dumb question, but...where is the throtal cable?</TD></TR></TABLE>
the throttle cable are those silver cables right in front of the throttle body, to adjust it, you loosen those bolts and adjust, and tighten to stay at the setting.
double check which one belong to the cruise control, i forgot which ones which.
Old Mar 16, 2004 | 06:03 AM
DIYaccord's Avatar
Default Re: Tighten Throtal Cable? (Mike813)
Ok, i didn't mean i didn't know where it was, i meant, i didn't know how to adjust it...and i tried looking it up in my manuel, and my manuel didn't even say where it was...
thank's mike813
Old Mar 16, 2004 | 07:18 AM
Accord6Gen's Avatar
Is is ok to tighten it? will it cause any problems or premature wear?
Old Mar 16, 2004 | 07:30 AM
Mike813's Avatar
Default Re: Tighten Throtal Cable? (H0nda Acc0rd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0nda Acc0rd &raquo;</TD></TR><TR><TD CLASS="quote">Is is ok to tighten it? will it cause any problems or premature wear?</TD></TR></TABLE>
well if your car dont need any adjustments itll cause yout idle to be super high, and gas comsumption will double, just check if theres any "slack" if so then tighten it just a little to get it right... its to give u a better response thats all, it should be checked every month if you like to floor it alot.
Old Mar 16, 2004 | 09:27 AM
SecretAznMan4u's Avatar
RICE RICE BABY, Doing this will do nothing but waste your time and fuel. Then in a few days,you'll be posting questions like "I adjusted my throttle cable and now my idle is really high, WTF???"....
If you are looking for free HP, try advancing your timing. smaller wheels, and get a damn 5 spd!!!
Old Mar 16, 2004 | 10:19 AM
DIYaccord's Avatar
Default Re: (SecretAznMan4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SecretAznMan4u &raquo;</TD></TR><TR><TD CLASS="quote">RICE RICE BABY, Doing this will do nothing but waste your time and fuel. Then in a few days,you'll be posting questions like "I adjusted my throttle cable and now my idle is really high, WTF???"....
If you are looking for free HP, try advancing your timing. smaller wheels, and get a damn 5 spd!!!</TD></TR></TABLE>
um...yeah...ok...how to start this, i know!
I'm not a ricer, i'm not looking for extra hp, i'm not looking to make my car faster...i just want to get rid of the slack in my accelerator pedal.
btw, does anyone know how to get my brake's to repond faster? would bleeding and flushing the brake fuild help?
Old Mar 16, 2004 | 10:20 AM
boonacka's Avatar
also, Weapon R makes a smaller throttle rotor that increases throttle response by reducing the distance the accelerator has to be pressed to open the throttle. I have this on my car, makes a noticable difference.
Old Mar 16, 2004 | 10:55 AM
raceACCORDingly's Avatar
Default Re: (DIYaccord)
btw, does anyone know how to get my brake's to repond faster? would bleeding and flushing the brake fuild help?</TD></TR></TABLE>
Stainless Steel braided brake lines
Old Mar 16, 2004 | 11:40 AM
Mike813's Avatar
how is this rice? adjusting your throttle cable if it is not working properly is a maintenance...
WTB AUTO EK
Mar 11, 2013 03:31 PM
UndergroundTuning
Feb 1, 2009 10:32 AM
delamission
Jan 21, 2006 03:15 PM
