ecilpse custom turbo w/intercooler for mini me
i have a 92 civic dx d15y7 block that with receive a mini me swap using d16z6 head. i will be putting an aftermarket intake manifold and turbo exhaust manifold with a mitsubishi eclipse used turbo and aftermarket intercooler. i will be doing the custom piping myself.
question: just to make sure, you can turbo this with no problems right? also, i plan to run a boost of about 6 - 8 psi. is that ok or should i run more or less?
i think the ecilpse turbo is made by garrett but i am not sure. i heard a lot of civic guys use these turbos to do custom set-ups. what do you think. any input is greatly appreciated. i plan to use a t3 or t4 set-up if that is helpful. thanks!
