all the small parts needed for a new swap!
im just making a list of the small things people dont usually talk about when doing a swap,
jdm b16a into 92 hatch:
motor oil
tranny fluid
brake fluid
cluch fluid
throttle cable
new coolant
spark plugs
feel free to add guys!
motor oil
tranny fluid
brake fluid
cluch fluid
throttle cable
new coolant
spark plugs
power steering fluid if you're gonna have that, towels, and hand cleaner
and remember to take breaks..... don't over work yourself till you get frustrated and start breaking thing.... and a 8mm punch to get the bitch pin out cause i got stuck on that.... and keep all your bolts and nuts and misc organized like in zip lock bags labled it helps a lot good luck
Depends on mileage really. The usual cap/rotor/plugs/wires/air filter/oil filter and such is a good starting point. If you've got substantially more mileage, perhaps look into a timing belt/tensioner/water pump/thermostat/hoses.
With the motor out of the car, its a lot easier to work on. So if you're coming close to a certain mileage that typically needs 'x' maintenance on it, just go ahead and do it now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcarothers »</TD></TR><TR><TD CLASS="quote">timing belt and water pump</TD></TR></TABLE>
...unless you get an engine with like 20-50K miles on it.
Hell Honda says replace them every 90K. If you get any swap with an actual known mileage under 60K I'd say don't worry about it unless you have the extra loot, which many people don't at the time of the swap.
I got all of my swaps with under 40K on them. The B16A that went into my fiancee's hatch only had 24K on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 »</TD></TR><TR><TD CLASS="quote">im just making a list of the small things people dont usually talk about when doing a swap,
motor oil
tranny fluid
brake fluid
cluch fluid
throttle cable
new coolant
spark plugs
throttle cable? i thought you could use your original one and bolt it up to the b series.
motor oil
tranny fluid
brake fluid
cluch fluid
throttle cable
new coolant
spark plugs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
I got all of my swaps with under 40K on them. The B16A that went into my fiancee's hatch only had 24K on it.</TD></TR></TABLE>
I would feel alot better if I had it changed. More than half the time you can't prove how many miles your swap has on it and in my opinion its worth the extra insurance. I will admit its definately not 'needed' but hey it helps to know exactly how long the belt has been on the car, and its alot easier to change with the motor out of the car.
supergtp1
Jun 2, 2014 10:22 PM
The Droogan Leader
Oct 23, 2005 07:04 PM
