car's running rich after cam swap
Old Mar 15, 2004 | 07:24 PM
shingles's Avatar
Default car's running rich after cam swap
or so says the ECU.
Car is a 98 GSR. Engine has a set of JDM ITR cams. It is otherwise stock. I've since done the valve adjustment three times, adjusted/checked timing twice, and replaced the spark plugs.
I have two problems though:
1) the car will sound like a diesel occationally when it is under load.
2) the car will throw a Running too rich code(based on the ODB II scan tool).
Any ideas why it's doing this?
O2 could be bad, but wouldnt it just throw a bad O2 code?
thanks,
-S
Old Mar 15, 2004 | 07:32 PM
doublejz's Avatar
Default Re: car's running rich after cam swap (shingles)
my guess would be timing
Old Mar 15, 2004 | 07:34 PM
Kataku2K3's Avatar
You shouldn't have any problems running R cams in a B18C, we do it all the time without any problem what so ever so it may just be a bad oxygen sensor. No other CEL tho? If possible I would try swapping it with a known good oxygen sensor for a bit. See if the problem comes back, if so then it's something else. You're just running a stock ECU, correct? Good Luck
Old Mar 16, 2004 | 06:06 AM
shingles's Avatar
Yes, everything is stock - ECU etc.
I guess I have to shell out for the O2. It's just that everything was fine before the swap. Car ran great.
Timing is at 16* TDC right now.
The thing is, I am not so worried about the richness - rather it's the noise I am worried about. I at first thought it might be knocking.. but then I am running rich. Can you run rich and continue to knock/ping?
-S
Old Mar 16, 2004 | 07:12 AM
CHEETAH's Avatar
and you're positive that your timing belt is perfectly timed and not couple tooth off ?
I'd be more concerned about the diesel sound sunder load, prolly could be valve/piston tapping from incorrect engine timing.
greg
Old Mar 16, 2004 | 11:16 AM
shingles's Avatar
Default Re: car's running rich after cam swap (CHEETAH)
Yes. Everything(timing mark on the gears) lines up correctly when I am doing the valve adjustments.
The odd thing is, the sound doesn't always happen even under the same load situation.
Old Mar 16, 2004 | 11:22 AM
SOHC_MShue's Avatar
my valves tap fairly loud with my zex stage 2 cam in my y8. This is mainly because of the high lift the cam has though. when I first installed the cam i adjusted the valves all crappy because I wasn't sure how tight a "slight drag" really needed to be. Now I have them adjusted right, but before that it definantely sounded like a diesel truck or something. Now my valves are much quiter, but still louder than stock...thats just from the cam though. So make sure you are adjusting the valves correctly.
turbotime
17
Dec 12, 2006 07:37 AM
Shonn
Oct 16, 2006 04:29 AM
AllMotorDA9
Oct 26, 2004 06:27 AM
herde1724
May 15, 2004 02:11 PM
jdmtim
Jan 26, 2003 10:58 AM
